Sat, Jan 25, 11:41 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Can the Poser 7 Pro feature Gamma Correction be emulated in P7 or P6 with Python
  • 1
  • 2
ice-boy ( ) posted Fri, 16 May 2008 at 12:03 AM
thanks for this
ice-boy ( ) posted Wed, 21 May 2008 at 3:41 AM
gamma correction and AO
made a third light that is in the back. i made the diffuse black so that i only get specular.30%
ground has also little AO.
ice-boy ( ) posted Wed, 21 May 2008 at 4:10 AM
bagginsbill ( ) posted Wed, 21 May 2008 at 6:10 AM
Nice - that doesn't look anything like a Poser render, does it?
ice-boy ( ) posted Wed, 21 May 2008 at 6:18 AM
its still not very realistic to me. but i didnt use very special lighting. normal lights with normal settings.
plus the background is complete fake. with a better background i think it would look 10 times better.
but your GC is what gets rid of the ''poser'' look
bandolin ( ) posted Fri, 23 May 2008 at 5:32 PM
Holy crap. I wish I knew what you guys were doing. I thought I knew shaders relatively well but I see I'm a complete ignoramus.
So far I've seen some pretty remarkable stuff  simulating exterior scenes. How does this apply to interior scenes?
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
ice-boy ( ) posted Fri, 06 June 2008 at 2:41 AM · edited Fri, 06 June 2008 at 2:44 AM
flibbits ( ) posted Mon, 20 April 2009 at 3:10 PM
If I apply VSS in PoserPro, should I turn gamma correct to 0?
bagginsbill ( ) posted Tue, 21 April 2009 at 2:09 AM
Quote - If I apply VSS in PoserPro, should I turn gamma correct to 0?
The answer is "no" but not for the reason you think. Let me restate your question a couple of times.
What does GC = 0 do?
It makes the response curve a flat line of pure white.
When should I use GC = 0?
You never, ever want to do that.
What does GC = 1 do?
It makes the response curve unchanged. It is the value to use when you want to disable GC in some rendering process.
When do I want GC = 1?
Overall? Probably never. However, as you move the GC from one stage in the process to another, you should only have one of them actually doing the GC - the other stages should be set to GC = 1 (no change).
So - if using VSS shaders with Poser Pro render GC set to 2.2, you should set the shader GC to 1.
If using VSS shaders with Poser Pro render GC set to 1, you should set the shader GC to 2.2.
If using VSS shaders with older Poser where render GC is not adjustable and is always effectively 1, you should always use the default shader GC = 2.2.
flibbits ( ) posted Sat, 25 April 2009 at 9:46 AM
Thanks for the answer.
  • 1
  • 2
