Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Nice - that doesn't look anything like a Poser render, does it?
Holy crap. I wish I knew what you guys were doing. I thought I knew shaders relatively well but I see I'm a complete ignoramus.
So far I've seen some pretty remarkable stuff simulating exterior scenes. How does this apply to interior scenes?
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
Quote - If I apply VSS in PoserPro, should I turn gamma correct to 0?
The answer is "no" but not for the reason you think. Let me restate your question a couple of times.
What does GC = 0 do?
It makes the response curve a flat line of pure white.
When should I use GC = 0?
You never, ever want to do that.
What does GC = 1 do?
It makes the response curve unchanged. It is the value to use when you want to disable GC in some rendering process.
When do I want GC = 1?
Overall? Probably never. However, as you move the GC from one stage in the process to another, you should only have one of them actually doing the GC - the other stages should be set to GC = 1 (no change).
So - if using VSS shaders with Poser Pro render GC set to 2.2, you should set the shader GC to 1.
If using VSS shaders with Poser Pro render GC set to 1, you should set the shader GC to 2.2.
If using VSS shaders with older Poser where render GC is not adjustable and is always effectively 1, you should always use the default shader GC = 2.2.
thanks for this
