Mon, Feb 3, 10:04 PM CST
Subject: GND4 Outfits Wishlist
Conniekat8 ( ) posted Thu, 05 June 2008 at 1:18 PM
Another one
witchdidi ( ) posted Thu, 05 June 2008 at 1:21 PM
Very very nice! Can't wait to see the other textures on it.
Be mad...until proven genius.
Sitting quietly in the corner does not make one the class fool.
- Didi
RDNA Store
Joe-B-Wan ( ) posted Thu, 05 June 2008 at 2:34 PM
This is definitely  a "gotta have it" item! It's absolutely gorgeous. I hope my finances are better off when it does come out.
stormchaser ( ) posted Thu, 05 June 2008 at 3:09 PM
Great work Connie!
The big day is getting ever closer! 👍
Conniekat8 ( ) posted Thu, 05 June 2008 at 3:21 PM
Yeah, Randy is importing all the morphs in today.
I haven't started on the textures yet. This week today is the first day I can spend some serious time on it.
When Randy is done with morph imports, I may release it for alpha testing. This will be for rigging and geometry/morph functionality only. Without textures.
stormchaser ( ) posted Thu, 05 June 2008 at 3:30 PM
Let me know when you'll need me Connie, I'm looking forward to working with it now it has the morphs.
How's things at home, will things be back to normal soon?
Conniekat8 ( ) posted Thu, 05 June 2008 at 3:40 PM
One more....
Stormy, Check your email
JoeB - Check your sitemail
stormchaser ( ) posted Thu, 05 June 2008 at 3:41 PM
Whoah, this is skintight!! :woot:
stormchaser ( ) posted Thu, 05 June 2008 at 3:42 PM
Thanks Connie!
Conniekat8 ( ) posted Thu, 05 June 2008 at 3:56 PM
Quote - Whoah, this is skintight!! :woot:
hehehe.... that was the idea, no?
FrankT ( ) posted Thu, 05 June 2008 at 4:05 PM
Wowee she's looking good in that Connie.  Can't wait for it to come out :biggrin:
My Freebies
Buy stuff on RedBubble
stormchaser ( ) posted Thu, 05 June 2008 at 4:31 PM
Quote - > Quote - Whoah, this is skintight!! :woot:
Yeah, that was the idea. Guess I just needed to see it again! 🤤
stormchaser ( ) posted Thu, 05 June 2008 at 6:36 PM
Had to have a quick play with it Connie!
Something was missing though, apparently she needed a couple of small guns.
Salmissra ( ) posted Thu, 05 June 2008 at 7:13 PM
Dig your idea of "small"!
This outfit is coming along wonderfully...has me sitting on the edge of my seat...hope I don't fall off!
Conniekat8 ( ) posted Thu, 05 June 2008 at 7:52 PM
I can't see the guns.... can you make them bigger :lol:
Spiffy render!!!!!
Conniekat8 ( ) posted Thu, 05 June 2008 at 7:53 PM
one more pic.....   Cute, but not nearly as nice as Stormi's guns
stormchaser ( ) posted Thu, 05 June 2008 at 7:56 PM
I was told that size doesn't matter.
Or was I being humoured?
stormchaser ( ) posted Thu, 05 June 2008 at 7:58 PM
That is one hell of a pose Connie, perfect for the outfit infact.
What are you using for rendering, Max, Carrara?
Joe-B-Wan ( ) posted Thu, 05 June 2008 at 8:40 PM
:thumbupboth:
vincebagna ( ) posted Fri, 06 June 2008 at 12:54 AM
Great news here! Happy to see it's going on so nicely!! ^^
Conniekat8 ( ) posted Fri, 06 June 2008 at 3:32 PM
Quote - That is one hell of a pose Connie, perfect for the outfit infact.
Yesterday's set of renders (with the beige outfit) are all poser renders... with AO and various quality settings near max... taking about 30-40 min per render.
Size doesn't matter? would you like a small ice cream or a big one?
Hey Vince, good to se you pop in :)
Conniekat8 ( ) posted Fri, 06 June 2008 at 7:37 PM
Testing a texture draft....
Conniekat8 ( ) posted Fri, 06 June 2008 at 8:32 PM · edited Fri, 06 June 2008 at 8:34 PM
A closeup. My AO sttings are little screwy, so I'm getting shadow artifacts... but I don't care to go about fixing that right now.
Joe-B-Wan ( ) posted Fri, 06 June 2008 at 10:10 PM
That texture draft is looking pretty nice. Is that a bit of pokethru on the ankles, or part of the texture?
stormchaser ( ) posted Sat, 07 June 2008 at 12:59 AM
Yeah, that texture looks great. Love the detail, I could almost reach out & touch it!
vincebagna ( ) posted Sat, 07 June 2008 at 3:30 AM
Looking at that texture, you seem to have very good UVs!
You should hide yourself full of shame to tease us like that!! Oo
Conniekat8 ( ) posted Sat, 07 June 2008 at 6:44 PM
Thanks guys.
I think I'm pretty happy about the UV's, except couple shoulder straps, the texture looks a bit big on them (which means they're little bit too small on the UV map)
But there's other ways around that too....
Conniekat8 ( ) posted Tue, 10 June 2008 at 2:03 PM · edited Tue, 10 June 2008 at 2:06 PM
Eye candy Time - trying out a different black texture.
kobaltkween ( ) posted Tue, 10 June 2008 at 2:20 PM
that's a lot better.  the scale is more realistic.
Conniekat8 ( ) posted Tue, 10 June 2008 at 2:35 PM
Thanks cobaltdream :)
Here's another view. This checkered pattern that shows up is driving me crazy right now. I can't figure out what setting is causing it to show up. Shading rate, AO, ligthing setup, something else.
When I didn't need it, I seemed to be seeing threads dealing with it left and right, now I can't find any to save my life.  Hrrrmph!
Conniekat8 ( ) posted Tue, 10 June 2008 at 2:38 PM · edited Tue, 10 June 2008 at 2:41 PM
Back side. Don't mind the pokethroughs... I'm still doing render tests on the unrefined rig.
kobaltkween ( ) posted Tue, 10 June 2008 at 2:47 PM · edited Tue, 10 June 2008 at 2:49 PM
i think that's what texture filtering fixes.  which is great if your on P7+, because you can apply it only to one material.  applied to a whole image, that'll slow things down.  i've had a similar problem with hair textures, and never found a solution. basically, the texture is so fine, it renders weirdly in Poser.  i have no idea if this is a problem in other renderers.  you can try rendering larger, getting your shading rate really low (and remember, the min shading rate is just a minimum, you actually have to select the group and change its shading rate), or maybe messing with the sampling and aliasing settings.  but i really don't know.
vincebagna ( ) posted Tue, 10 June 2008 at 3:13 PM
The checkered pattern, i had the same provlem some times ago. And i haven't find any solution :(
It seems to occur when your texture has very small repeated patterns, like your actual texture.
Conniekat8 ( ) posted Tue, 10 June 2008 at 3:37 PM
Hmmmmmmm... I've been playing with texture filtering... and with a number of other settings too a point I'm overwhelmed with them, and none of it is making sense any more.    Meow!
stormchaser ( ) posted Tue, 10 June 2008 at 4:39 PM
Hi Connie,
That texture is just what I was hoping for, I just love the fabric & detail.
Regarding the problem, if you want, you can send me the texture & I'll see what I can do with it in Poser.
Conniekat8 ( ) posted Tue, 10 June 2008 at 5:15 PM
Quote - Hi Connie,
Check you email :)
stormchaser ( ) posted Tue, 10 June 2008 at 5:39 PM
OK, thanks Connie.
I'll get back to you tomorrow.
Joe-B-Wan ( ) posted Wed, 11 June 2008 at 12:17 AM
Quote - > Quote - Hi Connie,
Check you email :)
Hey Connie, if you'd like I could give it looksie in C6 too.
Conniekat8 ( ) posted Wed, 11 June 2008 at 3:52 PM · edited Wed, 11 June 2008 at 3:54 PM
Joe - check your email :)
Since Joe had the cararra idea, I decided to run it through cararra myself too. Quick import. I dodn't tweak the shader parameters to get the same look as in previous poser renders, but I did use the same same texture maps. I probably didn't set the bump high enough, and I didn't bother setting it at all for the straps. I was just concerned with the main piece at the moment.
Talking to couple other people about the checker thing, it does to be a bug, or a limitation of firefly rendered. (YUCK)  As you can see in the pic, same texture in cararra, no problem-o.
Some days I wonder why I use Poser... today is one of those days.
stormchaser ( ) posted Wed, 11 June 2008 at 3:55 PM
Holy cow, that's the best screenie yet Connie, gorgeous! 🤤
Conniekat8 ( ) posted Wed, 11 June 2008 at 4:01 PM
Thnakees Stormy!
There are still couple things I need to figure out i cararra - like why my shadows aren't rendering soft, even though they are set to soft at the lights.... Byt, yea, much easier to get a better looking render in Cararra - or Vue. I didn't even use any of Cararra scene presets or environents, just imported poser lights!
stormchaser ( ) posted Wed, 11 June 2008 at 4:11 PM
It'd be great to see what you can do in Carrara when you have the settings just how you want them.
FrankT ( ) posted Wed, 11 June 2008 at 4:12 PM
looks very nice.  I bet it would look ace in Vue with a bit of fiddling around with highlights :)
My Freebies
vincebagna ( ) posted Wed, 11 June 2008 at 4:49 PM
Wow! Good one Connie! :D
In Carrara, don't think about the softness of shadows as in Poser. You have to set them up way higher, around 100 or even 500 with some lights. Give it a try ;)
Conniekat8 ( ) posted Wed, 11 June 2008 at 4:58 PM
Thanks Vince, that worked!
I actually had to crack open the manual LOL
........how does one crack open a PDF.... ?  😕
Rendering.... I cranked the settings up way high, so it'll be a few min... or so....
stormchaser ( ) posted Wed, 11 June 2008 at 5:01 PM
Quote - looks very nice.  I bet it would look ace in Vue with a bit of fiddling around with highlights :)
Hope to have something up tomorrow. Connie's set the bar higher now! 😉
Conniekat8 ( ) posted Wed, 11 June 2008 at 5:23 PM
Be afraid... be very afraid!
Yeah, that'll be the day, when I raise the quality bar on Stormy... more like th other way around!!!!
settings settings five milion render settings in six different applications....
I could have taken up something easier and more productive as a hobby - like knitting!  But, nooo, I have to be fancy and do three deee.... I need a nap, I get kicked out of bed early so I'm more cranky then usual .... and I like to hear myself complain. :lol:
stormchaser ( ) posted Wed, 11 June 2008 at 5:35 PM · edited Wed, 11 June 2008 at 5:35 PM
Well Connie, it could have been tougher. You could have knitted the StormChaser outfit!
Conniekat8 ( ) posted Wed, 11 June 2008 at 5:40 PM
Quote - Well Connie, it could have been tougher. You could have knitted the StormChaser outfit!
ROFL!!!!!
.......I actually can knit, but not all that well. My sewing is much better...
stormchaser ( ) posted Wed, 11 June 2008 at 5:45 PM
I was forced to knit in Primary School. We did it for a few months when I was about 8 years old. I'm ashamed to say I was actually quite good at it. Obviously not as good as you Connie.
One thing's for sure though. It won't be going on my CV!
