Forum Moderators: RedPhantom
Very very nice! Can't wait to see the other textures on it.
Be mad...until proven genius.
Sitting
quietly in the corner does not make one the class
fool.
- Didi
Yeah, Randy is importing all the morphs in today.
I haven't started on the textures yet. This week today is the first day I can spend some serious time on it.
When Randy is done with morph imports, I may release it for alpha testing. This will be for rigging and geometry/morph functionality only. Without textures.
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
Stormy, Check your email
JoeB - Check your sitemail
yurs?
BadKittehCo
and product support
Quote - Whoah, this is skintight!! :woot:
hehehe.... that was the idea, no?
yurs?
BadKittehCo
and product support
Wowee she's looking good in that Connie. Can't wait for it to come out :biggrin:
My Freebies
Buy stuff on RedBubble
I can't see the guns.... can you make them bigger :lol:
Spiffy render!!!!!
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
Quote - That is one hell of a pose Connie, perfect for the outfit infact.
What are you using for rendering, Max, Carrara?
Yesterday's set of renders (with the beige outfit) are all poser renders... with AO and various quality settings near max... taking about 30-40 min per render.
Size doesn't matter? would you like a small ice cream or a big one?
Hey Vince, good to se you pop in :)
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
Looking at that texture, you seem to have very good UVs!
You should hide yourself full of shame to tease us like that!! Oo
Thanks guys.
I think I'm pretty happy about the UV's, except couple shoulder straps, the texture looks a bit big on them (which means they're little bit too small on the UV map)
But there's other ways around that too....
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
Here's another view. This checkered pattern that shows up is driving me crazy right now. I can't figure out what setting is causing it to show up. Shading rate, AO, ligthing setup, something else.
When I didn't need it, I seemed to be seeing threads dealing with it left and right, now I can't find any to save my life. Hrrrmph!
yurs?
BadKittehCo
and product support
yurs?
BadKittehCo
and product support
i think that's what texture filtering fixes. which is great if your on P7+, because you can apply it only to one material. applied to a whole image, that'll slow things down. i've had a similar problem with hair textures, and never found a solution. basically, the texture is so fine, it renders weirdly in Poser. i have no idea if this is a problem in other renderers. you can try rendering larger, getting your shading rate really low (and remember, the min shading rate is just a minimum, you actually have to select the group and change its shading rate), or maybe messing with the sampling and aliasing settings. but i really don't know.
The checkered pattern, i had the same provlem some times ago. And i haven't find any solution :(
It seems to occur when your texture has very small repeated patterns, like your actual texture.
Hmmmmmmm... I've been playing with texture filtering... and with a number of other settings too a point I'm overwhelmed with them, and none of it is making sense any more. Meow!
yurs?
BadKittehCo
and product support
Quote - Hi Connie,
That texture is just what I was hoping for, I just love the fabric & detail.Regarding the problem, if you want, you can send me the texture & I'll see what I can do with it in Poser.
Check you email :)
yurs?
BadKittehCo
and product support
Since Joe had the cararra idea, I decided to run it through cararra myself too. Quick import. I dodn't tweak the shader parameters to get the same look as in previous poser renders, but I did use the same same texture maps. I probably didn't set the bump high enough, and I didn't bother setting it at all for the straps. I was just concerned with the main piece at the moment.
Talking to couple other people about the checker thing, it does to be a bug, or a limitation of firefly rendered. (YUCK) As you can see in the pic, same texture in cararra, no problem-o.
Some days I wonder why I use Poser... today is one of those days.
yurs?
BadKittehCo
and product support
Thnakees Stormy!
There are still couple things I need to figure out i cararra - like why my shadows aren't rendering soft, even though they are set to soft at the lights.... Byt, yea, much easier to get a better looking render in Cararra - or Vue. I didn't even use any of Cararra scene presets or environents, just imported poser lights!
yurs?
BadKittehCo
and product support
looks very nice. I bet it would look ace in Vue with a bit of fiddling around with highlights :)
My Freebies
Wow! Good one Connie! :D
In Carrara, don't think about the softness of shadows as in Poser. You have to set them up way higher, around 100 or even 500 with some lights. Give it a try ;)
Thanks Vince, that worked!
I actually had to crack open the manual LOL
........how does one crack open a PDF.... ?
Rendering.... I cranked the settings up way high, so it'll be a few min... or so....
yurs?
BadKittehCo
and product support
Be afraid... be very afraid!
Yeah, that'll be the day, when I raise the quality bar on Stormy... more like th other way around!!!!
settings settings five milion render settings in six different applications....
I could have taken up something easier and more productive as a hobby - like knitting! But, nooo, I have to be fancy and do three deee.... I need a nap, I get kicked out of bed early so I'm more cranky then usual .... and I like to hear myself complain. :lol:
yurs?
BadKittehCo
and product support
Quote - Well Connie, it could have been tougher. You could have knitted the StormChaser outfit!
ROFL!!!!!
.......I actually can knit, but not all that well. My sewing is much better...
yurs?
BadKittehCo
and product support
![file_407678.jpg](https://live.cdn.renderosity.com/forum/comments/3246057/file_407678.jpg)
Another oneHi, my namez: "NO, Bad Kitteh, NO!" Whaz yurs?
BadKittehCo Store BadKittehCo Freebies and product support
