Mon, Feb 17, 7:33 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Subject: Shiny renders
FreeeSpirits ( ) posted Fri, 06 June 2008 at 5:10 PM · edited Mon, 17 February 2025 at 7:20 AM
May I please borrow your expertise?
I've been trying in vain to get the same shiny renders in DAZ that I've gotten in Poser.
Because of limited time and knowhow, I'm hoping someone would kindly help me out so I can complete the DAZ-version of the ThingaMaJigMachine (a fun toy that makes random props).
The speed of the render is a very important factor, because the basic purpose of the ThingaMaJigMachine (apart from making props) is to stimulate creativity, and we all know how those loooong renders tend to vaporize our enthusiasm, don't we? My pathetic experiments with lighting and refraction and reflection took way too long and looked rather terrible    when compared to results from the Poser-version.
Here is a test scene for you to play around with (311kb zip). It includes a ThingaMaJig which was rendered from the Poser-version so you can see the type of effect that I'm after.
I would really appreciate your help in overcoming this hurdle - the person who sends me the shiniest speediest DAZ shader script will receive a full version of the ThingaMaJigMachine, as well as acknowledgement with a link to your website in the final distribution. More info and contact details in the attached zip.
Thanks
`_~
Trienie
Come and play with the ThingaMaJigMachine
Join the ArtStarters Club
Have you got all my freebies?
Want some Creative Inspiration?
RAMWorks ( ) posted Fri, 06 June 2008 at 5:17 PM
Attached Link: Super Shine Shaders for DAZ Studio
 Here you go...
---Wolff On The Prowl---
My Store is HERE
My Freebies are HERE
FreeeSpirits ( ) posted Fri, 06 June 2008 at 5:33 PM
Thanks very much for your quick reply!
They look gorgeous, I'm going to try them out right now.
`_~
Trienie
Incognitas ( ) posted Fri, 06 June 2008 at 7:13 PM
Thanks for that..I'm particularly impressed by the topcoat shader.
FreeeSpirits ( ) posted Sat, 07 June 2008 at 1:40 AM
Ditto. On round surfaces it looks absolutely stunning.
Unfortunately my ThingaMaJig looks washed-out and my textures fade away. Probably because it's a flat surface, and lights and camera are "out of the box" - I hope to keep it this way because I want to introduce my ArtStarters series to a group of raw newbies next.
I ran into the same problem when I made "Hearts for Dark Backgrounds" and found a solution, but for the life of me I can't remember how I did it. How embarrassing!
FreeeSpirits ( ) posted Sat, 07 June 2008 at 4:34 AM
Found the solution!
I decided to start from scratch, made a "stupid mistake" and got the desired result! Laughing
Originally I applied displacement on the texture and it looked dull and flat. When accidentally applying displacement to the shape instead, I had the effect I wanted.
Hope this helps someone sometime...
`_~
T
FranOnTheEdge ( ) posted Sat, 14 June 2008 at 2:24 PM · edited Sat, 14 June 2008 at 2:33 PM
Can't get them to work - as I've got no "Skin" tab and it seems that's how you use these things...
the shaders I mean, I was trying to put them on a sphere primitive.
I then tried loading up the thingamajig file, hoping that this may solve my problem with the sphere - and I get this error message:
So what does this mean by "correctly" what is "correctly" in this context?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
Incognitas ( ) posted Sat, 14 June 2008 at 3:32 PM · edited Sat, 14 June 2008 at 3:35 PM
You need to put them in the shaders folder.
Having said that you only really need the topcoat shader as you can choose a colour or texture for your primitive/figure through the surfaces tabs(under diffuse/colour) and then apply the top coat again making sure you have highlighted the figure/primitive in the panel above the shaders tabs as well as in the scene tab.
The topcoat is fantastic on floors in DS.Gives a floor that ballroom shine.
