Mon, Feb 10, 3:45 AM CST
Subject: V4 morphs not working right after installing V4.2 update
CStrauss ( ) posted Mon, 09 June 2008 at 11:34 PM · edited Mon, 10 February 2025 at 3:38 AM
Any one have this problem, I just updated my V4.1 to V4.2 I hesitated cause my fear was a lot of my other stuff for V4.1 or less would not work and sure enough I bought a product Bladerune by Rhiannon and installed it and went to go play with her and sure enough none of the morphs seemed to load :(.
I tried reinstalling the product thinking since it was a 2 part download maybe I forgot to install one but that wasn't the case so my guess is that V4.2 is not backwards compatable. Is this true or is there something else I should be looking at to fix this.
Thanks for any input you can give to me
Jules53757 ( ) posted Tue, 10 June 2008 at 12:41 AM
You ave to load (inject) the morphs into V4 before you can use characters.
Ulli
CStrauss ( ) posted Tue, 10 June 2008 at 1:03 AM
Yeah thats what I do with this product I go to poses click inj body, face, or full (which are the three option it gives to add the morphs) but nothing happens. So thats why I was wondering if perhaps there is a compatbilty issue with me using V4.2 and this product.
I tested some other products I have for V4 and everything seems to work fine but this product doesn't work so was just looking for people who had the same product or had similar issues with other products.
Jules53757 ( ) posted Tue, 10 June 2008 at 2:41 AM
Before you can use the INJ pose for a char you have to inject the V4 morphs, located in **RuntimeLibrariesPoseDAZ's Victoria 4Morph InjectionsMorphs++
Ulli
CStrauss ( ) posted Tue, 10 June 2008 at 3:27 AM
Yeah i found that and it works now, But I dont remember having to do that with the V4.1 or earlier version is that new with this update? Also there show two options when I go to that one that says something like base morphs and then one for Morphs++.
I did the morphs++ I'm pretty sure I did that right, cause it worked. But out of courisity whats the diffrence between them does the base just like remove all morphs and just make it a basic V4 char with no morphs.
Also I noticed on not all V4 chars I dont have to do that for it sometimes works fine with out having to load those morphs meaning I load V4 out of library then apply the morphs from what ever it shapes her just fine. Just some baisc explaination is all I'm looking for.
Again thanks for you help
Jules53757 ( ) posted Tue, 10 June 2008 at 4:42 AM
Well, V4 is making extensive use of the ReadScript command. While V4 had all morph data included in the cr2 so that a character needed only the respective settings for the morphs, the new characters use the Readscript to read the morph data, when the pz2 is professionally made. In this case there is no neet to load the morphs as the pz2 is looking for them. If not, you have to load the morphs manually.
Ulli
grichter ( ) posted Tue, 10 June 2008 at 9:16 AM
If your computer has the horsepower and you can deal with a little longer load time. Copy your V4.2 cr2. Open the copy and search on the word addChild.
Look a few lines above the word addchild and you will see he word figure. Above that there should be these two lines of code
readScript ":Runtime:libraries:!DAZ:Victoria 4:V4ERC.pz2"
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:InjDeltas.V4BaseAll.pz2"
Those add in the base morphs.  Now add this line right below those and V4.2 will load with all ++ morphs.
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:InjDeltas.V4Morphs++All.pz2"
I have a cr2 called V4.2Base (the original supplied by daz) and the hacked one I call V4.2++ (it loads all the ++ morphs if you own them)
The hack makes V4.2 behave like V4.1 but keeping in mind that the scene files saved off will be bigger and they take longer to load also.
Of course if you want a little longer load you can hack another cr2 and load all the above and the A4 morphs too :)
Just depends how lazy you are vs the amount of ram your computer has.
Hope this helps
Gary
Marque ( ) posted Tue, 10 June 2008 at 7:43 PM
Was finally going to install V4.2 and the version I have appears to only be for Daz Studio. Does anyone know the name of the file I need to reset to get the one for PC Poser?
Thanks,
Marque
