where did you download Bryce from? if it was DAZ then you may need to download the other files.
Experience is no substitute for blind faith.
http://avalon2000.livejournal.com/ -
My Art Blog
Attached Link: David Brinnen
Is this the tutorial of which you speak (the link above)? If so then this is the terrain map of which he speaks. As it says in the tut, it would be located in Disk 2 and it's name is Erosion2 and is in "tif" format and it measures 319x320 this uploaded image is a "jpg" conversion of that map and can be used in it's stead for the sake of that tutorial.After Bryce 4 I've only bought download versions. So!!!! I decided to do a quick search and although I have Bryce 6.1 installed here is the tif you are looking for.
C:Program FilesDAZBryce 6.1ContentTexturesLegacyTerrain MapsErosion2.TIF
and its 113KB.
If you didnt download and install the Bryce 5 presets, you can do so from here:
Hmmm, I don't know about anyone else, but I can't make this tutorial work at all. I was interested in the idea of adding to the sunlight in the right direction, but
a) all the settings for the terrains leave them hanging about in mid air,
b) the camera setting gives you a render that's almost black (the camera being way too close to the terrains) and
c) double clicking while holding down the alt key does put a yellow star in the scene to show the sun position, but all the settings are so far out of wack that you have to look above to find it, not just swing east or west.
(I'm assuming here that by "Alt Gr" he means the "Alt" key - since I only have an "alt" key, not an "Alt Gr" key, but I could be mistaken.
I thought originally it might be because I was following the tut in B6, so I tried again in B5.5 - same result.
If someone else has version 5 of Bryce, maybe this tut will only work for that, but it's darned hard work in B5.5 or 6
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran, I will try it out shortly as soon as I finish my latest project... I have glanced it over and am sure that if I follow it exactly as written, maybe I'll figure out where the problem lies.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Measure
your mind's height
Fran,
I followed the tut exactly... except with the <> which if you can recall the positioning of the sun??? Use the ctl key or its equivalent in the Mac keyboard. As for the dark item, did you remember to input the y rotation number for the mountain? You also need to use the camera as your view point, not the director camera. I swung the camera but did the easier thing.... I just inputted the numbers into the camera direction box and presto! There it was! And I did it in ver 6.1
Go ahead and try it again. Take your time and remember to fall back on your previous knowledge, Bryce wisdom or experience or whatever you call it....
:b_tonguewink:
I'll post my handiwork tomorrow as I would like to work on it some more... (Add trees, etc.)
I will post a bigger picture in my gallery later today but just wanted to show Fran that it can be done in ver 6 or 5... You just have to pay close attention to the instructions and use your experience with Bryce...
I could have missed something, I'm without a printer at present so I have to continually switch from screen to screen, backwards and forwards like a demented yoyo - usually I print out a tut so I can follow it properly.
I'll have to try again some time, I'm without the internet for some days soon, not sure how many, might be just a week or two, might be some months - so I might have to try it again in a few months. sigh...
Measure
your mind's height
I'm following a turtorial by David Brinnen. To be able to do it all i have to use terrain-mapps. I have dowloaded bryce and have no cd. Are the terrain-mapps not in the dowload version or have i missed an installation file?
