Tue, Nov 19, 9:20 AM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: Changing Poser Menu Direction *without* the Alt key?
Khai ( ) posted Sun, 22 June 2008 at 3:55 PM · edited Tue, 19 November 2024 at 7:18 AM
how does one change the direction of the Poser menu's in the work space from horizontal to vertical without using the Alt key?
I'm in ubuntu, and the ALT key controls the window only... it won't control anything in a program.
so, which Ini file/ config file and where do I set this?
(and I say again for the person that will pop up and say 'hold the alt key....' WITHOUT the alt key!)
svdl ( ) posted Sun, 22 June 2008 at 4:06 PM
Switching within Poser itself - wouldn't know how to do that without the Alt key.
Something that might work: start Poser under Windows, organize the layout the way you want it (including using the Alt key to change orientation), save it as your preferred state. The result ends up in the file "Poser UI prefs_.xml". In Poser 5/6 you'll find this file in /Runtime/prefs, in Poser 7/Pro you'll find it under Documents and Settings//Application Data/Poser 7 (or Poser Pro)
It might be possible to hand edit the file, but it's fairly large, and I don't know which elements contain the data for the orientations in the different rooms.
My gallery   My freestuff
nruddock ( ) posted Sun, 22 June 2008 at 4:34 PM · edited Sun, 22 June 2008 at 4:35 PM
Attached Link: http://www.nabble.com/Wine-Question-or-Suggestion--td17744968.html
A better solution is to fix the key assignment for the window manager your using, so that you don't run into the same problem with other Windows apps under WINE. Clues at the attached link.
Khai ( ) posted Sun, 22 June 2008 at 6:25 PM
ugh.. no please not 'clues'
thats how all tech support is done for linux.. rather than plain answers...
Khai ( ) posted Sun, 22 June 2008 at 6:43 PM
yay! thanks... the clues in tehre worked.. but damn if there ain't a lot of obnoxious twerps in that thread...
