Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Switching within Poser itself - wouldn't know how to do that without the Alt key.
Something that might work: start Poser under Windows, organize the layout the way you want it (including using the Alt key to change orientation), save it as your preferred state. The result ends up in the file "Poser UI prefs_.xml". In Poser 5/6 you'll find this file in /Runtime/prefs, in Poser 7/Pro you'll find it under Documents and Settings//Application Data/Poser 7 (or Poser Pro)
It might be possible to hand edit the file, but it's fairly large, and I don't know which elements contain the data for the orientations in the different rooms.
Attached Link: http://www.nabble.com/Wine-Question-or-Suggestion--td17744968.html
A better solution is to fix the key assignment for the window manager your using, so that you don't run into the same problem with other Windows apps under WINE. Clues at the attached link.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
how does one change the direction of the Poser menu's in the work space from horizontal to vertical without using the Alt key?
I'm in ubuntu, and the ALT key controls the window only... it won't control anything in a program.
so, which Ini file/ config file and where do I set this?
(and I say again for the person that will pop up and say 'hold the alt key....' WITHOUT the alt key!)
