Thu, Nov 28, 6:02 PM CST
Subject: Self illumination material in Bryce
DukeNukem2005 ( ) posted Wed, 28 May 2008 at 4:42 PM · edited Thu, 28 November 2024 at 6:02 PM
How to make self illumination material in Bryce?
dhama ( ) posted Wed, 28 May 2008 at 4:58 PM
Don't know if this is what you're after:
http://www.btinternet.com/~jarec/2020/tutorials/b4radiosity.htm
AgentSmith ( ) posted Wed, 28 May 2008 at 6:29 PM
Radiosity is bounced light from another source. Sounds like Duke is after what is referred to as;
*Self-Illuminated Objects/Material
*Light Emitting Objects/Material
Its when a mesh can itself becomes a light source, throwing light out in all directions in the shape of the mesh. Think glow in the dark platic toy that you would get out of a cereal box. Or, those glowing necklaces you would get at the fair.
Bryce cannot do this, it would have to be faked. But, not to put Bryce down, a lot of renderers cannot do this. But, its easier to find than what you would think, Blender can do it. (internally or with a 3rd party renderer like Indigo)
This is one of the ablilities I had discussed with DAZ to give Bryce 6 around when alpha testing had started, but it just couldn't be done (right now), and I'm not sure if we would ever want it in Bryce, as the render times would be ridiculous. (maybe later with the advent of 8 core cpus, lol)
AS
AgentSmith ( ) posted Wed, 28 May 2008 at 6:30 PM
Blender (internal) example.
AgentSmith ( ) posted Wed, 28 May 2008 at 6:31 PM
Blender, using the Indigo renderer.
brholte ( ) posted Wed, 28 May 2008 at 8:15 PM
You can do some creative rigging and achieve this in bryce.  Keep in mind I did this example in about 30 seconds,
.....but take whatever object you want to self illuminate, and give it some transparancy,  a little reflection, and select additive.  Next create a light source inside of the object and this is what you get.  With a little more time, you could probobly achieve better quality than what I presented here.
The thing I would have to figure out is how to get soft glowing edges instead of these hard ones.
and one more object from Bryce 5's imported objects section
mboncher ( ) posted Thu, 29 May 2008 at 9:21 AM
Using translucent materials you can kind of achieve the effect, but it's still faking the funk.  It involves you putting lights inside objects, and of course you're still dealing with ye olde fashioned "sphere and spot", not shaped like neon tubing.  Or a bazillion sphere lights made into the shape of the item... sort of.  I don't even want to concieve the render times on that.  My computer hates me enough as is. :c)
FranOnTheEdge ( ) posted Thu, 29 May 2008 at 1:57 PM · edited Thu, 29 May 2008 at 2:00 PM
How about this?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
alexclark ( ) posted Thu, 29 May 2008 at 3:15 PM
When I want something to look like its emitting light I fake it by ramping up the ambience value in the material editor and using gentle radial/spot lights. Depending on where the lights are it can be a good idea to switch off cast shadows for the 'light source' too.
FranOnTheEdge ( ) posted Thu, 29 May 2008 at 4:59 PM
Yup that's what I did there and here:
This one I also clicked on Additive for the element inside the bulb, as well as disabling sunlight and turning off the atmosphere, so here it's just the 3 radials; 1 in the green globe, 1 in the lamp and 1 in the naked bulb.
Both the naked bulb one and the lamp one are radials stretched out and squeezed thin.
(I also switched off cast shadows in the lamp and in the element inside the naked bulb, just so that the casting of light is the only thing you see, not the casting of shadows as well.)
Fran's Freestuff
alexclark ( ) posted Sat, 31 May 2008 at 12:22 PM
As I described above, but the 'light source' sphere material has been made additive. There is a second sphere with a custom volume material applied to try and achieve a 'glow'. No sunlight, just 1 radial with squared falloff.
pakled ( ) posted Sat, 31 May 2008 at 6:59 PM
wow..if Agent Smith can figure out the Blender menus, he can do anything!...;) sorta the approach I use, but not nearly so refined...;)
FranOnTheEdge ( ) posted Sun, 01 June 2008 at 2:07 PM · edited Sun, 01 June 2008 at 2:20 PM
alexclark,
How did you do that custom volume material?
I'm trying that just by duplicating the element and changing the mat that's already there to volume, and trying to boost the fuzziness a bit.
It'll probably take 6 years to render....
Fran's Freestuff
alexclark ( ) posted Tue, 03 June 2008 at 12:59 AM
Fran, Its an old one I have stored from when I was trying to create a realistic atmosphere. I've sent you a copy of it to your e-mail.
DukeNukem2005 ( ) posted Fri, 06 June 2008 at 10:18 PM
dhama, AgentSmith, brholte, mboncher, FranOnTheEdge, alexclark, pakled - Thanks for councils.
FranOnTheEdge ( ) posted Sat, 07 June 2008 at 11:38 AM
Thanks Alex, I'll take a look at the differences between yours and mine, should be interesting.
DukeNukem2005,
You're very welcome.  I find I usually learn something whenever someone asks a question.  So thank you!
Fran's Freestuff
FranOnTheEdge ( ) posted Tue, 24 June 2008 at 12:21 PM
Alex,
Can you give the settings for the bryce scene where you had the glowing sphere?  I'm trying out your 'atmos.mat' but so far it's not glowing yet...
Fran's Freestuff
alexclark ( ) posted Fri, 27 June 2008 at 12:25 AM
Fran, Are you using it on its own? It has to be 'wrapped around' another material before it looks like its glowing. You can just make out the 2 spheres in the wireframe here, and the light inside. The material settings on the left are for the inner sphere.
FranOnTheEdge ( ) posted Sat, 28 June 2008 at 5:53 AM
Oh you're using 2 spheres!  The material I made I just used the one, didn't need to duplicate the object.
That's interesting.  Thanks.
Fran's Freestuff
FranOnTheEdge ( ) posted Tue, 29 July 2008 at 11:01 AM
Er... I see you've got the Light Lab and the Material Lab open at the same time...
Is that only possible on the Mac?  Or can I do it on the PC too?
Fran's Freestuff
alexclark ( ) posted Wed, 30 July 2008 at 2:23 PM
Its possible if you edit your screen caps in GIMP to make posting easier : )
FranOnTheEdge ( ) posted Sat, 01 November 2008 at 4:19 PM
Ah, cheating, I like it!
Fran's Freestuff
pumeco ( ) posted Mon, 03 November 2008 at 2:52 PM
Check out the 'Glowing Objects' download at the link :
http://www.pumeco.com/pumeco/
FranOnTheEdge ( ) posted Wed, 11 February 2009 at 7:25 PM
What "Glowing Objects" download?
Fran's Freestuff
