Tue, Nov 19, 12:45 PM CST
Subject: Free Orb and 20 decorative glass shaders
bagginsbill ( ) posted Tue, 24 June 2008 at 5:46 PM · edited Tue, 19 November 2024 at 12:43 PM
Attached Link: Link to my free orb
A freebie prop and shaders by me. Go get it.
Thumbnails.
bagginsbill ( ) posted Tue, 24 June 2008 at 5:47 PM
Demo.
Demo
Demo
bagginsbill ( ) posted Tue, 24 June 2008 at 5:48 PM
Demo
Jules53757 ( ) posted Tue, 24 June 2008 at 5:49 PM
Thanks for this
Ulli
Jestertjuuh ( ) posted Tue, 24 June 2008 at 6:11 PM
Wow, nice shaders..thanks :biggrin:
Might find some use for those.
I am not a complete idiot, some parts are missing :)
To go to my home page, click the banner below.
Check my freebies on a regular base, click the banner below.
muralist ( ) posted Tue, 24 June 2008 at 6:19 PM
Really nice shaders;  thanks again.
Acadia ( ) posted Tue, 24 June 2008 at 6:37 PM
These are terrific! Better than I ever dreamed when I asked if it were possible!  :wub:
bagginsbill ( ) posted Tue, 24 June 2008 at 6:59 PM
I forgot to say this anywhere - if you're using Poser Pro with built-in gamma correction, these might not work too well. The reason is I already built gamma correction into these shaders.
In each shader, there is a node labelled PM:Gamma. The value is 2.2. If you want to use Poser's gamma correction instead, change that value to a 1. Then it becomes linear.
Also forgot to say that you can change the colors. Open a shader in the mat room. Look in the upper left area. Most have a SimpleColor - change that or plug stuff into it and make it white. Others use patterns, and you'll find one or two EdgeBlend(s) with two colors in it, or sometimes a Clouds node with two colors. The default color is that carnation-red. Where you see that, you'll know that's what to change. Several of the shaders mix that red with white or black. You can change the white or black, too, in most cases.
I'm looking forward to some renders from you guys! Some of the shaders (the plain glass ones) should work great on any prop. Try the "ThinGlass" one for windows.
dorkmcgork ( ) posted Tue, 24 June 2008 at 7:03 PM
wow! just now learning this too, great timing thanks
go that way really fast.
if something gets in your way
turn
FlyByNight ( ) posted Tue, 24 June 2008 at 7:07 PM
Thank you very much!
FlyByNight
YngPhoenix ( ) posted Tue, 24 June 2008 at 7:30 PM
Awesome! Thanks they look great.
pakled ( ) posted Tue, 24 June 2008 at 9:02 PM
thanks. Though I'm going to have 'fluffy little clouds' stuck in my head for the next hour...;) great work.
infinity10 ( ) posted Tue, 24 June 2008 at 10:03 PM · edited Tue, 24 June 2008 at 10:04 PM
Thanks - great stuff.
I'm using Poser 7, so should be fine with these.
Argh - need to add a comment:
Google asks for a log-in before folk can get to your freebie.
Eternal Hobbyist
Acadia ( ) posted Tue, 24 June 2008 at 10:07 PM
Quote - Thanks - great stuff.
I wasn't asked for a login.
bagginsbill ( ) posted Tue, 24 June 2008 at 10:08 PM
Quote - Google asks for a log-in before folk can get to your freebie.
Really? I thought it was open to all.
Anybody else? Did you have to log in?
I am able to download the zip without logging in.  But maybe that's because I'm the site owner and even though I'm logged out it somehow knows? As far as I can tell, if I'm not logged in, then I'm an anonymous user like anybody else.
bagginsbill ( ) posted Tue, 24 June 2008 at 10:10 PM
Acadia - this is the google site I was talking about. I can make you an author/collaborator, which means you can post and edit documents on the site.
Then we can assemble (little by little) all those material links nicely, instead of having to keep adding to a thread.
Interested?
Acadia ( ) posted Tue, 24 June 2008 at 10:11 PM
Quote - Acadia - this is the google site I was talking about. I can make you an author/collaborator, which means you can post and edit documents on the site.
Interested?
That would be great!
bagginsbill ( ) posted Tue, 24 June 2008 at 10:15 PM
@infinity: See? Public access to all - no login required as far as I know.
@acadia: I think you will need a google account (or gmail account works, too). It's easy to set up. PM me your email address and I'll use the form above to invite you. I think that's how it works.
dlfurman ( ) posted Tue, 24 June 2008 at 10:58 PM
Thank you kind sir!
bantha ( ) posted Wed, 25 June 2008 at 6:30 AM
I was able to get the zip without any login. Thank you very much! Your shader work is amazing.
-"Amazing Grace" Hopper
Whazizname ( ) posted Wed, 25 June 2008 at 6:35 AM
Excellent! Thank you for sharing them! (:
lululee ( ) posted Wed, 25 June 2008 at 9:31 AM
Thanks you so much for your constant generosity.
cheerio  lululee
Indoda ( ) posted Wed, 25 June 2008 at 9:50 AM
Thank you - excellent shaders and thank you for your generosity in sharing your knowledge
The important thing is not to stop questioning.
- Albert Einstein
Indoda
Indoda ( ) posted Wed, 25 June 2008 at 12:05 PM
General Attachment Error
We're sorry, but we were unable to locate the attachment you requested.
Does not seem I can download it at the moment ;(
- Albert Einstein
Indoda
RedHawk ( ) posted Wed, 25 June 2008 at 12:20 PM
Downloaded just fine for me....no login and no errors.....:thumbupboth:
...and thanks, BB!
<-insert words of wisdom here->
slinger ( ) posted Wed, 25 June 2008 at 12:48 PM
Oooooh!  SHINY! :¬)
Many thanks Bbill
The liver is evil - It must be punished.
Conniekat8 ( ) posted Wed, 25 June 2008 at 12:55 PM
Woo, most beautiful shaders!  Thanks so much for being so generous!
momodot ( ) posted Wed, 25 June 2008 at 1:00 PM
Wow! Thank you. This is so cool!
bagginsbill ( ) posted Wed, 25 June 2008 at 1:37 PM
Glad you guys like them.
Don't be afraid to open the shader and mess with the colors.
You can attach image maps too.
Here I'm using the "Pickled" shader. It makes the appearance of a nested sphere that is floating in liquid. I grabbed a map of the earth:
http://www.evl.uic.edu/pape/data/Earth/512/PathfinderMap.jpg
Then I attached it to the shader as shown. Click the image to see the the instructions.
Most of the shaders are really easy to do this with as they have a SimpleColor node for you to attach other nodes - just connect an image to the SimpleColor. Set the SimpleColor to White if you want the image colors to show exactly as they are. Or put another color in to "tint" the image.
bagginsbill ( ) posted Wed, 25 June 2008 at 1:37 PM · edited Wed, 25 June 2008 at 1:38 PM
Here is the render. Click for full size!
bagginsbill ( ) posted Wed, 25 June 2008 at 1:41 PM
Here it is in OpaqueCel.
bagginsbill ( ) posted Wed, 25 June 2008 at 1:46 PM
Here's the moon in #1, Opaque, with a light blue tint.
bagginsbill ( ) posted Wed, 25 June 2008 at 1:50 PM
Jupiter in #2, OpaqueFS.
FS stands for the bump style - using the FractalSum node.
Cel is using the Cellular node.
You can replace those bumps, too. Plug your own bump map or nodes into it. It will work with any bump pattern.
bagginsbill ( ) posted Wed, 25 June 2008 at 1:56 PM
#20, Rotor, is particularly interesting. You can connect two image maps to it, bypassing the stripes that are built in.
Click the image to see how to connect them.
Here is the render of Earth + Jupiter -> Rotor.
I've never seen anything like this in Poser before. I love to stare at it.
Nevare ( ) posted Wed, 25 June 2008 at 2:01 PM
You, Sir, are a genius, and your unceasing generosity to the community is beyond compare. THANK YOU!
grichter ( ) posted Wed, 25 June 2008 at 2:04 PM
Thanks a ton for all of this. But have an OT question. I can't seem to find the final results and the voting ended some days back. How did you do in the Have a ball primitives contest. I did my best Mayor Daley imitation and voted early and often for your entry :thumbupboth:
Gary
bagginsbill ( ) posted Wed, 25 June 2008 at 2:12 PM
The voting didn't end. One admin had a house fire, and didn't have a chance to deal with the contest.
Another admin came along, and postponed the announcement, because there was one entry that had not been approved, but was submitted before the deadline. Then there was some question about whether or not said entry met the conditions. It was then announced that the winner would be declared at midnight last night. Which hasn't happened. Now there are pissed people wanting blood. :biggrin:
Not me. I don't really mind if the admins are unable to process the contest. It's just a silly contest and delaying it hurts nobody - there is no prize, other than pride, and I'm already pretty certain my ego (large as it already is) will not be affected much either way.
Thanks for the vote!
Acadia ( ) posted Wed, 25 June 2008 at 2:38 PM
I'm so itching to get at these!!
I'm beta testing lesbentley's mirror magnets today, so once that's over, I'm on to shiney globes and to finish that render I was wanting them for.
