Fri, Nov 29, 9:55 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
Subject: Maps VS Shaders
nyguy ( ) posted Tue, 01 July 2008 at 12:27 PM · edited Fri, 29 November 2024 at 7:00 PM
I am currently working on a project in Poser and want to make 100% compatible with D|S.  Here is a render I did of it in D|S. Notice that the mirror has no reflection. In Poser there is a reflection (using Firefly) of the  front of the room.  I  went in to the surface  settings of D|S and cranked up reflection to 100% Still no reflection. How can I get that to show up in both Should I use a refection map or Shader for Studio?
secretroom_DS Render
Poserverse The New Home for NYGUY's Freebies
TheHalfdragon ( ) posted Tue, 01 July 2008 at 2:43 PM · edited Tue, 01 July 2008 at 2:45 PM
that's a great question cause i've been trying and to no avail on reflections so i'l watch and learn from this thread maybe lol
oh and i never knew you could mess up and post an empty post in here before just now lol
JenX ( ) posted Tue, 01 July 2008 at 3:12 PM
First things first...D|S won't reflect if there isn't anything to reflect.  So, if you've got dead space on the other side of the mirror, that's the best you're gonna get.
1.  There has to be light on the subject.
2.  Setting the diffuse color to black works best for me.
  1. Turn reflection all the way on
  2. Set Shader to Glossy Plastic.
TheHalfdragon ( ) posted Tue, 01 July 2008 at 3:14 PM
cool Jen umm would it work for glossy metalic as well?
JenX ( ) posted Tue, 01 July 2008 at 3:56 PM
It doesn't work as well.  The shader is a little different.
nyguy ( ) posted Wed, 02 July 2008 at 11:21 AM
I tired what was suggested and still cannot get a reflection. I even added more lighting to scene and just get white on the mirror surface. Would a reflection map work?
Akhbour ( ) posted Wed, 02 July 2008 at 1:08 PM
A reflectiomap would work, but that is not the best solution, honestly I never had to use mirror up to now. I'll do some tests and give you the results.
Peter
RHaseltine ( ) posted Wed, 02 July 2008 at 3:59 PM
What are your render settings? You need to be using the 3Delight render engine, the equivalent of Poser's Firefly, not any of the hardware OpenGL render settings.
Darklorddc ( ) posted Tue, 08 July 2008 at 6:33 AM
I, personally, have found that shaders do best at reflection. Look at the floor in the attached pic. I did that with a black metal shader from the freebie section here. As someone said...make sure you've got something to reflect, and the lighting doesn't have to be directly across from it. Also see if viewing the mirror from a slight angle helps.
nyguy ( ) posted Tue, 08 July 2008 at 7:27 AM
Quote - What are your render settings? You need to be using the 3Delight render engine, the equivalent of Poser's Firefly, not any of the hardware OpenGL render settings.
Yep that does the trick. Thanks.
