Sun, Feb 9, 5:57 PM CST
Subject: problem with bryce on external harddisk
boekenwuurm ( ) posted Tue, 01 July 2008 at 4:05 PM · edited Sun, 09 February 2025 at 5:51 PM
Hello, I have a problem.
My labtop harddisk is full, so I buyed an external drive for running bryce and dazstudio, by far the biggest programs on my disk. I backed up al my presets and uninstals bryce and dazstudio.
I instals both on the external disk, and D|S runs oke.
But bryce gives problems. I have 5.5 and 6-upgrade. I instals 5 and directly after that 6. The instalers are exactly the same as the one I used to instal the perfect working bryce on my labtopdisk, so no corupt downloads. Is this a common problem with installing bryce on a external hhd?
I get a message that the enterypoint of an .dll can not be fount. but the .dll are all in the same map as bryce. Can somebody helps?
TheBryster ( ) posted Tue, 01 July 2008 at 4:52 PM
I would question the wisdom of installing Bryce on an external drive. I think Bryce MUST be installed on C: ??      using the external as storage for some of  the stuff on your full hardrive.
AnnieD ( ) posted Tue, 01 July 2008 at 5:03 PM
Do you have an os installed on the external drive?  I think it may need to access your registry the same as other programs.
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
dhama ( ) posted Tue, 01 July 2008 at 7:00 PM
My Bryce is installed on a second drive... drive F to be exact, and it functions ok.
staigermanus ( ) posted Tue, 01 July 2008 at 7:45 PM
Quote - Hello, I have a problem.
Maybe your old installation that used to be on the C: drive removed a dll that was part of it but left the registry entry untouched and still have it 'point' to the C: location.
Maybe something else/similar with mismatched location.
Do you know which dll it is?
Have you searched the registry for 'Bryce' or that dll to see where the registry thinks it should be located? and is it actually at that location?
-Philip
thebest3d.com - beyond digital painting
boekenwuurm ( ) posted Wed, 02 July 2008 at 3:55 PM
I have the problem sloved for the important part! I don't know what the problem was, but I had problems with the amberkrn.dll file with bryce 5.5 and the dzcore.dll file with bryce 6. These .dll are in the bryce folder.
I uninstaled bryce 5.5, 6 and dazstudio. Then I install everything again with everything enabled (so install d|s 1.5 and 1.7) and bryce 6 works!
Bryce 5 did work until I instals bryce 6. Now it gives the amberkrn.dll enterypoint message again. Tomorrow I try to instal 5.5 again.
I want to ask you if it is possible to have bryce 5.5 and 6 on the same pc?
TheBryster ( ) posted Thu, 03 July 2008 at 5:51 AM
I think there are a few people who have more than one Bryce installation.
ThunderStone ( ) posted Thu, 03 July 2008 at 6:16 AM
Yes, it's possible to have both version on the same hard drive, just not in the same folder tho. I have 5.5 and 6.1 on my hard drive. I installed 5.5, well, that was the first one. Then I upgraded to 6.1 but the upgrade is to another folder. They play together nicely. Maybe you could install 5.5 , wait a day or so, then try installing 6.1 afterward??? :tongue1: Just kidding . Make sure you didn't install to the same directory/folder.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
boekenwuurm ( ) posted Thu, 03 July 2008 at 6:21 AM
Mmmm, not in the same folder? Then I think found my problem. This evening, when I'm at home, I try install bryce 5.5 in a different folder. Tnx!
AgentSmith ( ) posted Mon, 14 July 2008 at 5:44 PM
Yup, have as much Bryce as you want installed on your computer, just as stated, make different directory folders for each of them. I have Bryce versions 4, 5.0, 5.5, and 6.1 installed on my PC.
TheBryster ( ) posted Mon, 14 July 2008 at 6:07 PM
*I have Bryce versions 4, 5.0, 5.5, and 6.1 installed on my PC.
***AS is just a Brycian Animal!!!
Nice to see you about, Smithy!
AgentSmith ( ) posted Mon, 14 July 2008 at 7:03 PM
Nice to be about. ;o)
(on a work break for about a week right now)
ThunderStone ( ) posted Tue, 15 July 2008 at 5:44 AM
A short welcome back then, AS...
:b_grin:
