Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
Possibly the normals got reversed in the remapping process.
DPH
Nope, normals are fine. The textures are all at full strength in the materials room. There's nothing that should be making these invisible, save for the fact that the new geometry was (probably) made in UVMapper? I've had similar problems with other remapped items; could that be the issue?
I would do what John suggested and double check the names of the groups in the CR2 file and in the geometry and make sure that nothing got misnamed, such as lCollar becoming lCollar:1 . Also keep in mind that group naming is case sensitive. Also double check that you can just import the OBJ into Poser.
I have a prince outfit for Ichiro 1 originally made by Matsura, subsequently remapped and textured by Renapd. It always worked beautifully in Poser 4. I recently took it out of the archives, put everything where it was supposed to be, started up Poser, loaded my base figure, went to get the pants for the outfit, loaded them in, and --
... nothing. Poser "saw" them, because they registered in the hierarchy, but they were invisible and didnt render.
Thinking maybe something had gone wrong, I opened the cr2 in Word to check things, and it all seemed fine. I double checked the placement of the geometry, and it was okay as well.
Bottom line: everything is where it should be, except I cant see it. Any ideas, guys?
