IK is suppose to help this but when importing a BVH or using the Walk desiginer to create initial movement. The IK means absolutely nothing. Imean the feet will not lock down. I have tried to keeframe the foot so that it does stay put uppon impact but always with poor results. I'll take a look at the hip z axis but again The BVH file seems to change things. I'll double check that hip. Acceleration would occur as the foot is leaving the ground. Deceleration would occur just after the foot passes the top of the arc of the foots path and then continue to a brief stopping point when it actually hits the ground before beginning to accelerate again. JanP
I'm currently making models for a RPG game, someone else is doing the animations. When I get the animated PZ3 file back I get.... yep sliding feet. All I do is open the PZ3 in an editor and delete the x, y and z Translate data in the channels section of both feet. This cures the problem and the animation works correctly.
Not saying that this is the full solution, but it works for what I am doing.
So we all who have tried to animate have probably had trouble with sliding feet at one time or another when using BVH files. The zygote/DAZ supplied BVH's appear to change the makeup of the Poser characters. For example when you are positioning an appendage you already know that the Y axis is up/down, x axis is left/right and the z axis is foward backward. Now apply a BVH. Now look in the raph editor. Select a foot. you will see that now it is the x axis that controls foward/backword movement of the foot. Not the z axis. Anyway I wanted to stop the feet from sliding when they are on the ground. If a fott is acurately pllanted on the ground and no sliding, its x axis graph line will be perfectly flat. This is indeed what you see in Poser but guess what. The foot is no planted at all but indeed still slides. I then began to think that it was another appendage causing the sliding affect like a shin , thigh or even the hip. But they also appear to be graphed correctly. Its as if the BVH is actually walking in place but being pulled on a string. Exactly how the walk designer appears. Seems to me that adding something in poser to firmly loc the feet on the ground at a given frame should have been terribly easy to implement. Alas I am not a program and forget about Python. I might as well be trying to read martian. Any ideas? JanP
