Sat, Jan 11, 3:47 PM CST
Subject: Collison Detection in Poser 7
Cybertenko ( ) posted Tue, 08 July 2008 at 1:31 PM · edited Tue, 24 December 2024 at 12:39 PM
Hallo to everybody. I can use some help how to correctly base models in poser 7 - meaning putting them on ground so they not floating no drowning in the ground. I am trying to  set collision detection on  on scene, ground, and both feet of model, but still  figure  hangs in the  air or diving in the ground. Is there some trick or python script for easy basing?
bagginsbill ( ) posted Tue, 08 July 2008 at 1:36 PM
Press ctrl-D
Cybertenko ( ) posted Tue, 08 July 2008 at 2:25 PM
this command seems a little bit unprecise for me since it sinks boots into ground.
bagginsbill ( ) posted Tue, 08 July 2008 at 2:57 PM
It does? Then the figure you're using is messed up.
What Ctrl-D does is drop the item precisely so that the lowest part of it is exactly on the ground.
It has always worked for any prop or figure I've used it on. I use it all the time. I drag something to a new position and drop it.
Cybertenko ( ) posted Tue, 08 July 2008 at 3:41 PM
OK, I will it try once more. Thanks for your help.
JOELGLAINE ( ) posted Tue, 08 July 2008 at 4:49 PM
Ctl+D will always sink boots into the ground plane. It's a well known glitch. If you select the main figure (IE: Mike3,Vic3,etc) ANY footware will sink below the lowest part of that figure because the footware remains conformed to the main figure.
If you elevate the main figure and select the footware and go Ctl+D  the footware will fall to the floor, NOT the main figure.  There is no "Smart Drop" like in Vue in Poser where groups can be dropped like one figure.  I wish there was.
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
bagginsbill ( ) posted Tue, 08 July 2008 at 5:20 PM
Ah - I guess that's true. I don't encounter that too often.
Cybertenko ( ) posted Wed, 09 July 2008 at 12:48 AM
JOELGLAINE: yes thjat is exactly what I mean. Any solution for that?**
Purrdey ( ) posted Thu, 10 July 2008 at 7:03 AM
make sure you have ground shadows off (display ===> ground shadows
sometimes P7 makes things look like they are below ground when they aren't.
Also, with the outfit containing the boots, there is sometimes a foot pose for the model to make the boots sit correctly.  That might help.
