Tue, Dec 3, 5:05 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Creating gaps in an ecosystem
MarkHirst ( ) posted Wed, 09 July 2008 at 3:44 PM ยท edited Tue, 03 December 2024 at 5:02 AM
I've only had ecosystems for a little while so this might be obvious.
I want to site a vehicle (but it could have been a building for that matter) in a dense forest / jungle setting.
I've maxxed out density to get the thick coverage, but need to prevent the trees from growing through the vehicle. I thought the 'Avoid overlapping instances' option might stop this, but it kills the density I wanted, and the trees still grow through the vehicle model anyway.
Anyone know how to do this?
Using Vue 6 Pro Studio BTW
www.CambrianMoons.com
thefixer ( ) posted Wed, 09 July 2008 at 3:47 PM
The way I do it:
Place vehicle then do the eco system using the "decay near foreign object" and set it about 5%, that should do it.
Injustice will be avenged.
Cofiwch Dryweryn.
AVANZ ( ) posted Wed, 09 July 2008 at 6:15 PM
Or... you open the ecosystem material, click on paint and use the eraser brush to remove the trees manually.
Cheers!
http://www.charm3d.com
MarkHirst ( ) posted Thu, 10 July 2008 at 9:48 AM
Thanks for the hint on the decay option. Of course it was right there in front of me and I didn't realise its significance. Had to play around with the settings but I now have what I was after.
offrench ( ) posted Fri, 11 July 2008 at 2:27 AM
Another option that can be useful for accurate distribution is to drive the ecosystem density with a bitmap image. Geekatplay studio have good tutorials showing this.
Fantasy pictures, free 3d models, 3d tutorials and seamless textures on Virtual Lands.
Thelby ( ) posted Sat, 12 July 2008 at 8:05 AM
Vue Pro Studio does not have the Paint Ecos Options!!!! So you can not erase them either!!! You can also create a desity map as outlined in this LINK
I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
