Sun, Feb 16, 5:46 PM CST
Subject: multianimation on poser
JORDI ( ) posted Fri, 22 June 2001 at 2:19 AM ยท edited Mon, 10 February 2025 at 5:33 AM
It's possible to add a diferent characters on a poser animation or it's ONE ONLY SCENE FOR ANIMATION?, please it's very important to send me your answers. Thanks JNOVAU@MENTA.NET
doozy ( ) posted Fri, 22 June 2001 at 9:27 AM
A poser scene (even an animated one) may have many characters in it. Is that what you mean?
jamball77 ( ) posted Fri, 22 June 2001 at 11:47 AM
If you want to add another character select it from the character library then click on the double check mark at the bottom.
nevin ( ) posted Sat, 23 June 2001 at 4:29 AM
You can also IMPORT poser characters in case you've created each one seperately (which is highly reccommended). Simply go to file->import->poser prop*-> This will bring up the load/import window where you can select your file. You'll want to change the format to .pz3 (or whatever) and browse to the correct folder. That's it. It's been a loooong night for me so I hope this makes sense. You'll want to learn how to fully utilize the different cameras to do animation. For example, I use the Main Camera and Aux Camera for POV, then I use the Posing Camera to lock onto each figure for actual posing; Hand Cams are especially helpful for handshakes and such. You get the idea. Be careful though, I myself am addicted to this whole animation deal... ADDICTED... 0_o' *not sure of the actual label here, I'm at work ^_^
doozy ( ) posted Sat, 23 June 2001 at 8:09 AM
He explained privately that what he meant was to change one figure into another during an animation.
