Sun, Oct 6, 6:18 AM CDT
Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Subject: Needed a litle help...
tom271 ( ) posted Sat, 02 August 2008 at 8:27 PM · edited Sun, 06 October 2024 at 4:44 AM
I'm working on a street scene I originally made in Rhino and re making it in Bryce materials...
One of the objects I am having trouble with is a hand rail on a fire scape.   Here is the image and I hand drew the rail...  How best to approach this...   that curve really numbs me out...
johnyf ( ) posted Sat, 02 August 2008 at 8:41 PM · edited Sat, 02 August 2008 at 8:47 PM
Try Steves Art Gallery.
He has some great primitives to download which are ideal for this!
http://stevesartgallery.bryce-alive.net/
oop's....should have visited the site first, these aren't the ones I was thinking of.
Still worth grabbing though!
Sorry, can't remember where to get the one's I mean!
wildman2 ( ) posted Sat, 02 August 2008 at 8:49 PM
draw it a paint program make it a lattice
"Reinstall Windows" is NOT a troubleshooting step.
johnyf ( ) posted Sat, 02 August 2008 at 8:53 PM · edited Sat, 02 August 2008 at 8:54 PM
This is the site.........http://www.iaw.on.ca/~jspirko/
However, it says they are no longer available as downloads, but he will send them if you email him!
Or you can let me have your email addy, and I will send them!
wildman2 ( ) posted Sat, 02 August 2008 at 9:17 PM
here is a real quik render with the handrail drawn in psp as bmp and pgm
wildman2 ( ) posted Sat, 02 August 2008 at 9:20 PM · edited Sat, 02 August 2008 at 9:21 PM
and the source file. if saved as a pgm it's a lot cleaner Or you could use the smart pipe gizmo.
tom271 ( ) posted Sat, 02 August 2008 at 10:40 PM
Thank you for your input..   A lattice is flat and I need it 3d....    It is a whole street model scene..  here is what I got so far..
johnyf ( ) posted Sat, 02 August 2008 at 10:48 PM
You could always boolean a turus for the curve and add a cylinder to lengthen!
bikermouse ( ) posted Sun, 03 August 2008 at 12:00 AM
Something along these lines?
Use a path and straighten it out and then add a bend at the end.
Make a cube and re size it to fit your specs
In attributes make the cube positive
in attributes/link select parent and use the name of your path as the parent also check the box that says constrain to path
exit attributes.
in multi replicate choose 100 copies -  x offset put 0.05
multi replicate
select all the boxes.
there is a chain link looking thing two boxes below the attributes select it and G will appear select that.
Congratulations : you have just accomplished multi replicating a cube along a path !!
done.
tom271 ( ) posted Sun, 03 August 2008 at 12:35 AM
I'll try it...  hope it works with cylinders....  Thank you.....
wildman2 ( ) posted Sun, 03 August 2008 at 2:02 AM
a lattice is not flat
a pgm image would be best.just import it.
TheBryster ( ) posted Sun, 03 August 2008 at 7:11 AM
Forum Moderator
Tom: You'll find a handrail in my file-locker. Hope it helps.
tom271 ( ) posted Sun, 03 August 2008 at 5:20 PM
Thank you Bryster...   It did serve the purpose...   I must learn to do them my self...  what did you use for the actual curve..?   meta balls?      here is a pic of the fire scape
TheBryster ( ) posted Sun, 03 August 2008 at 5:37 PM
Forum Moderator
Tom: Checkout SPACEBONES. He has loads of free objects that I find extremely usefull.
tom271 ( ) posted Sun, 03 August 2008 at 11:22 PM
Thank you I did... very nice stuff he has..
TheBryster ( ) posted Mon, 04 August 2008 at 8:21 AM
Forum Moderator
Tom, why on earth didn't you just copy and dismantle the Handrail I left?  You would know how it was created then.
electroglyph ( ) posted Mon, 04 August 2008 at 12:04 PM
Make a positive bryce torus. create two negative bryce blocks and position them to where they intersect 90 degrees of the torus. group and you have the curved section. Rotate and lengthen a bryce cyllinder off each end and you have the rest of the rail. Mirror, rinse, repeat for the other end.
tom271 ( ) posted Mon, 04 August 2008 at 2:54 PM · edited Mon, 04 August 2008 at 2:56 PM
@Bryster:  I did break it down..   your curve at the center was all mesh...  here it is and with a torus imposed on it..  your curve seems to be slight different from the torus curve...   I wanted to learn to do curves of different angles...  torus gives a 90deg.  can I do 120deg..
@electro..  Yes,, I got to experiment till I learn to get different curves...
TheBryster ( ) posted Mon, 04 August 2008 at 3:08 PM
Forum Moderator
Tom: Send me an e-mail addy would you?
electroglyph ( ) posted Mon, 04 August 2008 at 3:35 PM
Just rotate the block Z 120 degrees then line the corners back up and to the center of the torus.
electroglyph ( ) posted Mon, 04 August 2008 at 3:41 PM
In Bryce 6 you can edit the torus. The default is 256 but you can make the pipe thicker or thinner.
tom271 ( ) posted Mon, 04 August 2008 at 4:25 PM
Bryster.. I sent you my e-mail...  but you know that since am a coordinator I have a renderosity site address...
**electroglyph: ** This is the first time I ever saw that function....
I need to go to an appointment will be right back in two hours or so....
