Sun, Jan 12, 12:21 PM CST
Forum Moderators: Staff
Subject: Bump Maps Rendering Model's MESH in Poser 6+ ?
pizzone ( ) posted Wed, 06 August 2008 at 5:32 AM · edited Sun, 12 January 2025 at 12:35 AM
Hi,
I already checked previous posts so I know it's something other people found before. Using a bump map on a model in Poser 6 or 7 (I didn't check if it's the same for P5; for sure it wasn't in P4PP..) takes a very strange (and very annoying) effect: besides the desired bump effect you were actually looking for, carefully setting your bumpmap, you get a bonus: a light (but clearly evident) bump-effect that renders the mesh structure of the model. It happens both in Firefly and P4 rendering. At first I thought I forgot a "template layer" on my bumpmap, but in the end it looks like the effect is "mesh based" and comes out whenever you use a bump map. Well, as I alredy told, I'm not the first one to experience it, but did anyone succeed in solving it? Since it's present both in P6 and P7 it looks like e-frontier (or Curious Labs or whoever is the actual owner of P...) didn't notice it? Is there an update to solve the problem? I admit I didn't read all the posts about it, but I don't consider "solving the problem" setting the bump values to 0,00...; the mesh structure sure disappears... along with the bump effect you were looking for! Thanks to everyone who will have the patience to help,
              Alberto
Miss Nancy ( ) posted Wed, 06 August 2008 at 3:10 PM
post screen cap of bad bump/mesh interaction, along with screen cap of materials room
settings.  ISTR there was something about using gradient bump, or else just drop bump
and use displacement channel.
pizzone ( ) posted Wed, 06 August 2008 at 3:27 PM
OK, I'll try with displacement. Thanks
EnglishBob ( ) posted Wed, 06 August 2008 at 4:25 PM
Last I heard, bagginsbill had filed a bug report with Sith Micro - so there may be a fix sometime around Poser 9 or 10... :)
If you're using a map which uses mid-grey to represent "no bump", as Poser 4 bump maps did, you'll get this effect. You can use a math node to subtract 0.5 from the bump map, which will return the mid-point to zero. It helps on some maps, but won't be 100% effective on them all.
pizzone ( ) posted Thu, 07 August 2008 at 4:41 AM
Thanks, I'll try that, too.
bagginsbill ( ) posted Thu, 07 August 2008 at 6:46 AM
I did post a bug, and they did fix it.
You want Poser 7 SR3.
EnglishBob ( ) posted Thu, 07 August 2008 at 3:39 PM
Kudos to SM, in that case. I retract my previous allegations of sloth. :-)
pizzone ( ) posted Fri, 08 August 2008 at 5:08 AM
Wow, I'm sure gonna grab that SR3!!!
Thanks to everybody!!!
