Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 4:13 pm)
If you need to see both sides for adjustment and setup, try using one
of the Wireframe display modes.
My python page
My ShareCG freebies
Poser does not have the ability to display back faces in preview. It'll render them in final renderings, but will not display them in preview.
Is there a specific reson you want to see them in a preview, other then it being very annoying to not see the back sides?
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
I think personally that the preview renders have a freshness all of their own and also it's the speed.
Pity their render wasn't as good as Max. I use both and I find it a pain as I usually build the same models in each program for different reasons.
Max for adjusting vertices and renders and poser for speech, expression, model manipulation, clothing and all Daz has to offer.
I wish there was a program that encompassed all of these........You don't know of one do you?
Cheers billythekid
Quote - I just found a way to do it.......... 1 I opened another (cuirass) tunic
2 hid the parts I didn't want.
3 reversed the normals
4 conformed itwalla
billythekid
This is a very useful trick. Poser's Preview Renderer is now very good, IMO, it often gives me what I need. Just remember that you can texture the reversed surface differently-- this will give you a cloak interior which is different than the cloak exterior; in the case of the Roman tunic, it looks like you're getting interior textures correctly from the UV mapping, but this won't always be the case
Quote - I think personally that the preview renders have a freshness all of their own and also it's the speed.
Pity their render wasn't as good as Max. I use both and I find it a pain as I usually build the same models in each program for different reasons.Max for adjusting vertices and renders and poser for speech, expression, model manipulation, clothing and all Daz has to offer.
I wish there was a program that encompassed all of these........You don't know of one do you?Cheers billythekid
I can't tell for sure if it has everything you ae looking for, but have you tried cararra?
Clever cheat on the backfacing issue!
yurs?
BadKittehCo
and product support
is it possible to render two sides of clothing, for example, using only the preview renderer.
HOW DO I GET DOUBLE-SIDED RENDERS IN PREVIEW using poser 6?
Is it possible...I thought I did it in the past reversing the normals but can't remember what I did.
thanks in antisipation....billythekid
