It should work - here is a tutorial on using it. [
http://users.tns.net/~mwalter1/External_Render.pdf](http://users.tns.net/~mwalter1/External_Render.pdf)
LVS - Where Learning is Fun!
There are some standard things you should check.
#1 is the e-onsoftware folder in "images" on all machines? In old versions when this folder is missing the result is a black image, as you describe it.
#2 Does the Cows (all of them) have the same build number as your Vue? This is important and i knopw that on Mac the automatic update of cows not always works as it should!
Thanks all for the replies,
Wabe,
My rendercow version is 6.05 build 289768 but i cannot find any update on the e-on website
My Vue 6 Infinite is version 6.60-04 build 292547, so clearly these versions do not match.
I also checked the e-on software folder in 'images' and it's there.
Bruno,
I chose a 'jpg' format with dimensions 1409x881 pixels dpi 72
Peggy,
I just followed the steps like you said in your tutorial (i used a much simpler scene for this test which had a render time of 00:00:06) but suddenly it renders okee !
This is a very strange thing :huh:
Gonna test it now with my finished scene again and will let you know as soon as it is done rendering that it is working or not.
Thanks
Wim
Society failed to tolerate me...
... and i have failed to tolerate society
Hi,
I rendered for the first time with the standalone render option, and after 1 hour and 15 minutes rendering, all i get is a total black image that is only 20k in size ??
What has gone wrong here ?
Wim
