Sun, Jan 26, 6:32 PM CST
Subject: External renderer
sirenia ( ) posted Mon, 18 August 2008 at 7:27 AM · edited Sat, 25 January 2025 at 5:02 PM
Hi,
I rendered for the first time with the standalone render option, and after 1 hour and 15 minutes rendering, all i get is a total black image that is only 20k in size ??
What has gone wrong here ?
Wim
Society failed to tolerate me...
... and i have failed to tolerate society
bruno021 ( ) posted Mon, 18 August 2008 at 4:44 PM
What image format did you specify? This is a rather strange one...
Peggy_Walters ( ) posted Mon, 18 August 2008 at 5:46 PM
It should work - here is a tutorial on using it.  [
http://users.tns.net/~mwalter1/External_Render.pdf](http://users.tns.net/~mwalter1/External_Render.pdf)
LVS - Where Learning is Fun!
thundering1 ( ) posted Mon, 18 August 2008 at 9:09 PM
Thanks  Peggy - got some big animations coming up in the next few weeks - gonna give this a try!
-Lew ;-)
wabe ( ) posted Tue, 19 August 2008 at 1:06 AM
There are some standard things you should check.
#1 is the e-onsoftware folder in "images" on all machines? In old versions when this folder is missing the result is a black image, as you describe it.
#2 Does the Cows (all of them) have the same build number as your Vue? This is important and i knopw that on Mac the automatic update of cows not always works as it should!
sirenia ( ) posted Tue, 19 August 2008 at 7:32 AM · edited Tue, 19 August 2008 at 7:32 AM
Thanks all for the replies,
Wabe,
My rendercow version is 6.05 build 289768 but i cannot find any update on the e-on website
My Vue 6 Infinite is version 6.60-04 build 292547, so clearly these versions do not match.
I also checked the e-on software folder in 'images' and it's there.
Bruno,
I chose a 'jpg' format with dimensions 1409x881 pixels dpi 72
Peggy,
I just followed the steps like you said in your tutorial (i used a much simpler scene for this test which had a render time of 00:00:06) but suddenly it renders okee !
This is a very strange thing :huh:
Gonna test it now with my finished scene again and will let you know as soon as it is done rendering that it is working or not.
Thanks
Wim
sirenia ( ) posted Tue, 19 August 2008 at 9:44 AM
Indeed it rendered just fine now, as i follow Peggy 's steps...
This time it was rendered in about 30 minutes and the file size is 1,2 MB
Nevertheless this is a strange phenomenon !!
