Sat, Feb 8, 9:27 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: GIDome 2 the HDRI set [commercial]
GKDantas ( ) posted Sun, 24 August 2008 at 4:21 PM · edited Sat, 08 February 2025 at 9:23 PM
HI people this is just to let all know that my new GIDome is in the Daz3D stores. This time its a set of HDRI images to be used in your indoor renders, yes thats right! This set was created for internal environment mood. The idea is to mimic some studio light setup.
http://www.daz3d.com/i.x/shop/itemdetails/-/?item=7559&cat=421&_m=d
Follow me at euQfiz Digital
sparrownightmare ( ) posted Sun, 24 August 2008 at 4:45 PM
Looks great.  I really have to start getting into HDRI.  I have never used it yet.
Miss Nancy ( ) posted Sun, 24 August 2008 at 4:58 PM
it looks very nice IMVHO.  do the settings allow caustics?
GKDantas ( ) posted Sun, 24 August 2008 at 5:45 PM
You can use caustic but I didnt try it (just in the test render). Look at the Wiki for the product that there are more about it .
http://artzone.daz3d.com/wiki/doku.php/azproduct/7559
stardust ( ) posted Sun, 24 August 2008 at 9:44 PM
Hi GK -
In your wiki, what is your room model setup like in your sample renders? (how many walls, etc).
Thanks!
GKDantas ( ) posted Mon, 25 August 2008 at 8:33 AM
Hahaha... only two wall theres and the Sky Light intensity was about 4000! I dont know why I need to use this value in this scene. I will upload an image from the camera so people can see this
GKDantas ( ) posted Mon, 25 August 2008 at 8:41 AM
Here is the scene in Assembler Room
boeing ( ) posted Tue, 02 September 2008 at 1:56 PM
GKDantas, I just bought this set and its incredible...excellent work!!
GKDantas ( ) posted Tue, 02 September 2008 at 5:20 PM
Thanks Boeing, I will realease one free sample so people can try too, but will be a new one.
boeing ( ) posted Thu, 04 September 2008 at 9:51 AM
Excellent, I again can't thank you enough for this lighting!  I do most renders indoors and found that with a floor 2 walls and even a ceiling (2 walls invisible or deleted) with a bulb or other light it looks even more realistic!  Since  2 of the 4 walls are not in the scene you still have enough HDRI lighting getting in that gets magnified by my light.  The light or bulb is usually only 20 feet throw distance with a falloff of 80%..just enough to really bring out the HDRI lighting.
Can't wait to see the new one!
GKDantas ( ) posted Thu, 04 September 2008 at 2:03 PM
Hey Boeing, show your render to us! I will post the new one on friday at CGShare... just wait a little more.
boeing ( ) posted Thu, 04 September 2008 at 9:03 PM
Here is what a good HDRI light can do....
GKDantas ( ) posted Fri, 05 September 2008 at 7:16 AM
Wow!! Very good render!
GKDantas ( ) posted Fri, 05 September 2008 at 3:37 PM · edited Fri, 05 September 2008 at 3:37 PM
FREEBIE!!
Here is the free sample for my GIDome 2 HDRI pack, BUT this is a totally new HDRI image that you will not find in the pack here!
http://www.sharecg.com/v/28391/material-and-shader/GIDome-2-free-sample
boeing ( ) posted Sun, 07 September 2008 at 9:01 AM
Thanks GKDantas!  That render was using the number 2 HDRI with a bulb.  I can't wait to try the freebie, looks like its a nice soft room setting.
GKDantas ( ) posted Sun, 07 September 2008 at 9:05 AM
Thanks Boeing, this freebie is in Renderosity free stuff now too.
JonnyBravo ( ) posted Fri, 12 September 2008 at 3:53 PM
I must be missing a step. I downloaded the HDRI zip file. Extracted to the Carrara 6 Pro Scenes folder, opened Carrara, added theGIDomeFreeSample folder to the browser, but when I click on the tab there's nothing in there...no icons to click and drag into the scene.
Help...what am I missing?
stardust ( ) posted Fri, 12 September 2008 at 3:57 PM
You need to extract it to your Carrara 6 folder, not the scenes folder :)
JonnyBravo ( ) posted Fri, 12 September 2008 at 4:58 PM
Quote - You need to extract it to your Carrara 6 folder, not the scenes folder :)
Thanks for helping me on this....I extracted to my Carrara Folder. I still dont see it....now what?
I would be more than happy to purchase GI Dome but want to be sure I can use it first. Thanks for your help.
stardust ( ) posted Fri, 12 September 2008 at 5:09 PM
Oh I'm sorry - I thought you were extracting the product - my bad. The freebie is just a zip, so you will have to apply the hdri map as you would load any other. Just unzip wherever you want to save the files.
GKDantas ( ) posted Fri, 12 September 2008 at 5:20 PM
Yes, Discoseven is right. The pack use a installer to put all files in right place. The freebie you can put anywhere ( I usually put in a HDRI folder under Textures folder).
JonnyBravo ( ) posted Fri, 12 September 2008 at 6:11 PM
Quote - Yes, Discoseven is right. The pack use a installer to put all files in right place. The freebie you can put anywhere ( I usually put in a HDRI folder under Textures folder).
Hmmm...Normally I either double click or click and drag a texture / object / pose / light ect. icon into my scene to apply, but there aren't any icons, in the browser tab, to click on. Is there another method of applying HDRI?
(The folder has been added to my Carrara browser...but there aren't any icons in it.)
GKDantas ( ) posted Fri, 12 September 2008 at 7:50 PM
Yes, click in you SCENE instance and load the HDRI as a Background (Choose HDRI from the dropdown menu). Look the image. In the pack there are icons to load the images... not in the freebie.
JonnyBravo ( ) posted Fri, 12 September 2008 at 8:52 PM
Thanks GK!
That's the step I was missing. Thanks for your help...it works great now.
GKDantas ( ) posted Fri, 12 September 2008 at 9:33 PM
You are welcome, show your renders to us.
GKDantas ( ) posted Sat, 13 September 2008 at 7:18 AM
Just to let to all know that this frrebie and the packs works in POSER too as IBL lights!
