Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
You can use caustic but I didnt try it (just in the test render). Look at the Wiki for the product that there are more about it .
Follow me at euQfiz Digital
Hahaha... only two wall theres and the Sky Light intensity was about 4000! I dont know why I need to use this value in this scene. I will upload an image from the camera so people can see this
Thanks Boeing, I will realease one free sample so people can try too, but will be a new one.
Excellent, I again can't thank you enough for this lighting! I do most renders indoors and found that with a floor 2 walls and even a ceiling (2 walls invisible or deleted) with a bulb or other light it looks even more realistic! Since 2 of the 4 walls are not in the scene you still have enough HDRI lighting getting in that gets magnified by my light. The light or bulb is usually only 20 feet throw distance with a falloff of 80%..just enough to really bring out the HDRI lighting.
Can't wait to see the new one!
Hey Boeing, show your render to us! I will post the new one on friday at CGShare... just wait a little more.
Here is the free sample for my GIDome 2 HDRI pack, BUT this is a totally new HDRI image that you will not find in the pack here!
http://www.sharecg.com/v/28391/material-and-shader/GIDome-2-free-sample
Yes, Discoseven is right. The pack use a installer to put all files in right place. The freebie you can put anywhere ( I usually put in a HDRI folder under Textures folder).
Quote - Yes, Discoseven is right. The pack use a installer to put all files in right place. The freebie you can put anywhere ( I usually put in a HDRI folder under Textures folder).
Hmmm...Normally I either double click or click and drag a texture / object / pose / light ect. icon into my scene to apply, but there aren't any icons, in the browser tab, to click on. Is there another method of applying HDRI?
(The folder has been added to my Carrara browser...but there aren't any icons in it.)
Just to let to all know that this frrebie and the packs works in POSER too as IBL lights!
![file_412612.jpg](https://live.cdn.renderosity.com/forum/threads/2748228/file_412612.jpg)
HI people this is just to let all know that my new GIDome is in the Daz3D stores. This time its a set of HDRI images to be used in your indoor renders, yes thats right! This set was created for internal environment mood. The idea is to mimic some studio light setup.http://www.daz3d.com/i.x/shop/itemdetails/-/?item=7559&cat=421&_m=d
