DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Save a pose preset for the single frame at the start and apply it at the end. You could also select all the nodes you will want to have in the orignal position, go to the frame you will want to be the final key, and click the make keyframe button before starting to adjust the intermediate poses
I believe the Animator plugin shows keyframes in its palette.
I currently playing around with making anims in D|S, its fairly easy, except that if I for example want to make my figure jump I animate the jump in several steps, but the last step (keyframe) should then be identical to the first one, ok, i could adjust everything to normal manually, but if I changed like 30 values thats a bit timeconsuming, it really must be a way to copy a keyframe and insert it again ? or.. ?
I searched and tried several ideas with no success.. :/
..It would also be nice to have keyframes marked in the timeline, I have a very vauge memory that I seen this before ? ..maybe that was in some another program however.
