Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 22 4:04 pm)
What is the polygon/point count on this thing? At that size, it must be hundreds of thousands if not millions of polygons and points. Poser can't handle that. Poser can barely handle V4. ;)
In Cinema 4D, use the Polygon Reduction deformer or, if you have used HyperNURBS, reduce the subdivision values. Then reexport.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
i have an object i wish to import in to pp ichose import obj when the progress bar gets to the end i ge the following error you are out of memory please save your work and quit soon when i click ok the program just crashes to windows .ive not got the most powerfull of pcs but i would have thought it was up to the job 3GHZ dual core 3GB ram 758MB video ram on the graphics card over 2TB empty hard drive space runing win xp. file size of the object is 570 MB any one able to help
