DAZ|Studio F.A.Q (Last Updated: 2024 Sep 30 1:31 am)
have you added any lights to your scene ? if you have you can click on the scene tab on the right of your work area and you can select the lights individually, then in your parameters scroll down to the bottom and you'll find a colour bar and intensity bar as well as the shadow settings.
and no worries about being new and not knowing cause well i only found this out about a month or two ago and i have been playin around in DAZ for a year and a half
It also looks like you are rendering in OpenGL mode, and not in 3Delight mode. Try switching to 3Delight :)
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
This looks very much like a render with too much light and no shadows. As HalfDragon says, you can select your lights in the Scene tab, just like a character or prop, and if you scroll all the way to the bottom you'll see the intensity slider. I try not to run more than 50-60% intensity from any one light. To add shadows, go to the "Shadow Type" dropdown and select your preferred method. I like 3Delight but it's really a fairly minor difference. Then make sure your render tab is set to do a Software Render.
Here's a decent little tutorial on lights and cameras:
digilander.libero.it/maclean/DStutorial.htm
The DAZ version is slightly outdated, so some of the screenshots may look odd to you, but the information is still good.
Hope this helps!
