Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Ha! Make it swim with the fishes as my Italian uncle would say. That sounds odd for poser 7, which i have only used on a mac and in XP. Never a problem like that, or any other really that was not caused by human error. Now Poser 6 was a hole nother story. Well, hope someone here can help!
coocoo
oh, by the way have u reset the preferences and failing that, perhaps a reinstall? and then watch this video for a laugh if you have to reinstall Vista too...http://www.youtube.com/watch?v=fVyTnTdijog
Lol...thanks for the laught Coocoo!
Phil, I put the textures in the texture folder I created for that purpose....but now you have me wondering if I am pullling them from there. I checked...yes, I am. I deleted what I had done previously, redid the material for one item.....but when checking in explore the folder I set up in Materials is still empty.
The mc6 file does not appear in a search. As I said before the folder I created in the Materials Library, so I could transfer the info to the Pose Library. is empty. I searched all of P7...and it does not appear anywhere.
I can howver go to Materials in P7...and it shows my object with the textures applied. I can click on each texture and change the appearance...and render....but nothing shows in the Material file in explore.
If it helps, the path on my pc is: Program Files/efrontier/Poser7/Runtime/Libraries/Materials/SandDancr/SS-ModLounge
I read my post again and small mistake came up. First I mentioned about mc6 but later on I wrote a correct extention mt5. But now:
As PhilC says Poser doesn't do anything to your textures it only writes references to them with extentions mt5 (mc6) and what you see in Poser Library is that reference. So I assume you cannot find those references, am I right?
Okay this is easy!! Go to your Material room and in the render window click on your object see where the file is selected or stored? Right click on that folder and copy it and make a shortcut to it on your desktop. follow it that way. For some reason Poser does not show the runtime folders and in some cases the textures or object files so you have to go in another way.. thats how I do it when I am making textures for my charchters or editing an object file.. Hope this helps
The problem is you're on Vista and those files are hidden. I ran into the same thing until I started storing an external runtime on my desktop and worked from there. Doing that, everything was visible. Annoying but that's Vista's way of protecting you from ...you.
There should be a way to unhide system/hidden files but I don't recall it. If you make a scene collection and save it to a runtime on your desktop though, it's likely that everything will show up and should - should - be in the proper places.
Ahhhh, the poor fishes are going to be deprived...... it works by putting it on the Desktop...just not inside Poser 7.
I checked and all my files were already unhidden...so for some reason P7 won't put them where you want in P7...but by trying Teyon's idea of using a desktop Runtime...I magically have files!
Thank you all for helping to discover the problem...I appreciate it more than you can imagine. In fact, I'll give you all a free copy of the product, just for being so helpful, if you like. Just pm me with your email.
Thanks again!
I am sooooooo extremely frustrated with P7, I am ready to box it up, run out the door, across the sand, and drop kick it to the fishes. Let them play with it!
I have had intermittant problems with it from day one. It shuts down for no particular reason, etc, etc, etc. All the SR's have been applied.
My latest problem is in getting ready to package several items for sale.
1: I imported the object, went to the material room, applied the image-map and settings, saved it to the library. All the material selections appear in Poser''s Material Library...I can select them , apply the different textures...no problem. When I go to Explore and choose the path to the Material Library...I can see my folder, no problem. However, opening that folder presents me with nothing...it is empty! No textures, no images, nada, zip, nothing...just plain old white space.
2. i imported the obj files to a folder in Geometries... this time I can see the content in my folder in explore.... but am getting zip in Poser. My file is empty in Poser. So I tried doing one item as a Prop. It appears as a prop in the Poser's Prop Library. Allows me to add it to a scene.....but when looking in explore....the folder is once again empty.
Obviously I am missing something... I have followed every tut I could find to a tee...but nothing seems to work correctly. Does anyone have a clue as to what could be wrong or to what I am NOT doing correctly?
Help, please..... or the fishes can have fun figuring out what to do with the package.
By the way, did I mention I am on Vista....would that have anything to do with it?
Thanks in advance....any assistance will be most appreciated.
