Mon, Jan 20, 1:07 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 19 8:07 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Deforming a Circle Mesh
DramaKing ( ) posted Tue, 21 October 2008 at 12:13 PM · edited Thu, 16 January 2025 at 7:33 PM
I have a circle, which I have extruded and converted to a mesh. Now the problem is that the edges run only from side to side and that doesn't give me good results when I try to deform it. ![](http://cid-5fae5cb5e1b96403.skydrive.live.com/self.aspx/Public/blender%7C_screen.jpg) Now is there a simple way to add edges to the mesh?
It is better to do one thing well, than to do many things and excel at nothing.
lisarichie ( ) posted Tue, 21 October 2008 at 6:38 PM
CTRL+E>loopcut or hot key K  for the knife tool to cut across existing edge loops.
jestmart ( ) posted Tue, 21 October 2008 at 9:49 PM
Start over and this time don't use a Curve circle.  Start with a Mesh circle (reduce to 16 verts) this will allow you to control how the faces and edges are made.
DramaKing ( ) posted Tue, 21 October 2008 at 10:39 PM · edited Tue, 21 October 2008 at 10:43 PM
Quote - CTRL+E>loopcut or hot key K  for the knife tool to cut across existing edge loops.
Thanks for the tip. I think that was somewhere in the back of my mind, but I got the crazy idea of connecting the vertices with F. I didn't want to do that, though, because it would have been too tricky and time-consuming.
Quote - Start over and this time don't use a Curve circle.  Start with a Mesh circle (reduce to 16 verts) this will allow you to control how the faces and edges are made.
I'll try that, too.
DramaKing ( ) posted Mon, 08 December 2008 at 9:20 AM · edited Mon, 08 December 2008 at 9:21 AM
Attached Link: Edit Mode
Okay, time for an update. I tried using a Cylinder, but that wasn't any better. I eventually went into 3ds max where I could manipulate the mesh density of the cap ends. (Sometimes, I wonder how Blender gets along without some of this stuff). And that looked okay when I imported the cylinder mesh into Blender, but it still wasn't showing the correct wireframe in Object Mode.
Reddog9 ( ) posted Mon, 08 December 2008 at 9:57 AM
I don't understand what you're trying to accomplish.  You say you want to deform it, how do you mean?  Why not just add a plane..   sub surface it 4 or 5 times and then apply the modifier?
You'll get what I got above.
Won't that work for what you want?
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
DramaKing ( ) posted Mon, 08 December 2008 at 12:24 PM
Won't that work for what you want?-
Yeah, sorry, I'm trying to take a mesh that looks a lot like that and use the Sculpt tool on it. I've tried several methods that failed, but this one looks like it could actually work. Now that I think about it, I could've probably used retopo or bump mapping. Ah, well.
Thanks a lot :)
Reddog9 ( ) posted Mon, 08 December 2008 at 11:44 PM
I see.  Hope that works for you.
Reddog9
