Thanks, but that didn't help. I also tried deleting the poser.ini but that didn't help either.
My computer specs are winodws xp sp3, 2.13 ghz processor, 2 gig memory, ati radeon 9600 vid card. I don't think this is it though because poser was working fine for a while. don't know what happned.
could some one help me. I am trying to render a still scene in pose 5 and work on it in photoshop but the resolution is low 72.00 I need at least 300 so i can print out. I need a higher resolution. How can i do that. please help. Is it possible in poser 5 or do i need to upgrade. Thank you Christine
generationxgarden@yahoo.com
your vid screen is set to 72dpi, if you have rendered to a new window at a higher res ie300dpi you should see a slider on left side and a slider on the bottom of the window. you need to adjust these to see parts of your image.you won't see all the image at once, the screen cannot display it.
that's the limitation of most ( if not all ) lcd and crt screens. even HD doesn't come anywhere near 300 dpi.
hope this helps
....if I reinstall poser one more time. Poser 7 started locking up if I tried to delete something, import something (like an .obj, or .3ds), cothify something. It doesn't seem to matter if I use sr2 or sr3. Has this happened to anyone else? I've tried defragging the computer and reinstalling poser like a billion times to the point that I'm afraid my compter will strick if I try it again. Any suggestions?
edit: oh i've also made sure my drivers are updated
