Tue, Nov 19, 5:45 AM CST
Subject: My computer is threatening to strike...
RedPhantom ( ) posted Thu, 30 October 2008 at 9:05 PM · edited Tue, 19 November 2024 at 5:43 AM
Site Admin
....if I reinstall poser one more time. Poser 7 started locking up if I tried to delete something, import something (like an .obj, or .3ds), cothify something. It doesn't seem to matter if I use sr2 or sr3. Has this happened to anyone else? I've tried defragging the computer and reinstalling poser like a billion times to the point that I'm afraid my compter will strick if I try it again. Any suggestions?
edit: oh i've also made sure my drivers are updated
markschum ( ) posted Thu, 30 October 2008 at 10:17 PM
delete the xml config files in the application data /poser 7 folder under documents and settings
The libraryprefs.xml gets rewritten and can become corrupted .
You may need to respecify external runtimes after deleting the file but Poser will recreate it .
RedPhantom ( ) posted Fri, 31 October 2008 at 7:35 AM
Site Admin
Thanks, but that didn't help. I also tried deleting the poser.ini but that didn't help either.
cspear ( ) posted Fri, 31 October 2008 at 7:42 AM
What are your system's specifications?
PoserPro 11 - Units: Metres
Adobe CC 2017
Anthanasius ( ) posted Fri, 31 October 2008 at 12:00 PM
I don't think that the computer specification is in fault ... A little couple of time i've a little bug under poser 7 sr 2.1, when i move the camera, it move at large like x=5000 y = 5000 for exemple ... I just install over the sr2.1, not poser and all is ok !
Génération mobiles Le Forum / Le Site
RedPhantom ( ) posted Fri, 31 October 2008 at 5:58 PM
Site Admin
My computer specs are winodws xp sp3,  2.13 ghz processor, 2 gig memory,  ati radeon 9600 vid card. I don't think this is it though because poser was working fine for a while. don't know what happned.
generationxgarden ( ) posted Mon, 08 December 2008 at 6:31 PM
could some one help me. I am trying to render a still scene in pose 5 and work on it in photoshop but the resolution is low 72.00 I need at least 300 so i can print out. I need a higher resolution. How can i do that. please help. Is it possible in poser 5 or do i need to upgrade. Thank you Christine
generationxgarden@yahoo.com
hborre ( ) posted Mon, 08 December 2008 at 6:45 PM
@ generationxgarden: go to render dimension to make your changes.
generationxgarden ( ) posted Mon, 08 December 2008 at 7:04 PM
DO I HAVE TO CHANGE THE RESOLUTION from 7200 to 300? When I render it then open it in photoshop the image is still 7200. AND when I render to another window the image is black no image.
3anson ( ) posted Tue, 09 December 2008 at 12:26 PM · edited Tue, 09 December 2008 at 12:27 PM
your vid screen is set to 72dpi, if you have rendered to a new window at a higher res ie300dpi you should see a slider on left side and a slider on the bottom of the window. you need to adjust these to see parts of your image.you won't see all the image at once, the screen cannot display it.
that's the limitation of most ( if not all ) lcd and crt screens. even HD doesn't come anywhere near 300 dpi.
hope this helps
