Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Thanks everybody. I did have a problem doing it that may not be apparent in the you tube video. After mapping an image onto a square plane and adding an alpha channel which was pure black and white, I still saw a very light gray color wher the image was supposed to be transparent. Any ideas what I'm doing wrong?
Yep, that's the same sort of issue I've had; you might try putting your alpha channel info into the transparency channel, as well, but I haven't had that help much. Fortunately for this kind of mograph look, having that little light frame doesn't detract; in fact, it kind of feels like it should be there. But it's maddening when you can't get it to work. I'd suggest adding this to Daz's bug report. Lack of full alpha accuracy can really screw up someone's day....
:D
Attached Link: http://community.victoriaadvocate.com/home/Blog/rzavala/9276
I just did a "Coming attraction" video using Carrara to do the 2d animation in the style of the Watchman motion comics. You can see it at my blog. The URL is the link.Let me know what you think.
Robert Zavala
