Most of the time only Transmapped hair has any kind of realism in Bryce. In Bryce4 you have to bring the Transmap in manually after you figure is in. Be careful though some hair models (ie: hmannn's Total Hair)are very complex in their "mesh names" so make sure you know where all the transmaps go if there is more than one. Kozaboru's hairs come out beautiful in Bryce. (Rob)
I figured it out!!!!! I was not putting the mark in the bottom transparency. That made it work just fine. I reduced the ambiance and diffusion from 100 to about 75 and it worked. If it ever finishes rendering, I'll post the finished shot. Thanks everybody for the help. It is all starting to make more sense. It is taking so long to render this small image it is unbelievable. I am excited about Bryce 5 being able to use the shared resources of network computers. I have 7 computers (2 Macs 7 Pc) and will be able to set up all my renders and let the 7 computers do the work together at night. Sounds like it is going to be pretty cool. Well thanks again.
Looks really good Shutter. There does seem to be two points of light in the "part" area of her hair....specularity too high? Or too much reflectivity maybe? Great start thought. (Rob) P.S. If either is the case I might suggest a specularity no higher than 30 to 35 unless you lights are very close to her then less Spec. Reflectivity either don't use or use very low setting like 1.6 to 3.
I can import my Poser characters into Bryce just fine. I can get the eyes correct and the eyelashes, but all the hair I bring along with the figure looks just like a wood carving instead of hair. If I render the same hair in Poser it look pretty much like hair. What am I doing wrong? Is there a tutorial anyone knows about? Thanks This is my first time to post a question, but I have gotten a lot of help from reading other members questions.
