Sat, Feb 8, 9:15 PM CST
Subject: can i put snow on fir trees
bigdave1960 ( ) posted Tue, 02 December 2008 at 9:04 AM · edited Sat, 08 February 2025 at 9:01 PM
I have some fir trees in vue 6 infinite that i want to use in a winter scene is there an easy way to put snow on them? Im a bit of a novice at vue so the more straight forward the better
ranman38 ( ) posted Tue, 02 December 2008 at 9:29 AM
in the material editor, create a new layer and add a white layer to the fir tree. There is a tutorial out there somewhere. I will look for it.
gillbrooks ( ) posted Tue, 02 December 2008 at 9:31 AM
There are several ways of doing it.
If you want total whiteout on your leaves, jjust set the overall colour to white in the colour correction box on teh colours and alpha tab
If you want only bits of snow, use a mixed material driven by a fractal and you can also set the height and slope functions on the influence and environment tab.
If you desparately need something, IM me with your email address and I'll send you one of mine.
Gill
bigdave1960 ( ) posted Tue, 02 December 2008 at 10:32 AM
heres my email         bigdave1960@hotmail.co.uk
gillbrooks ( ) posted Tue, 02 December 2008 at 10:54 AM
Email sent to you with the tree attached.....and a link to something else 😉
Gill
bigdave1960 ( ) posted Tue, 02 December 2008 at 11:15 AM
Thank you very much , just going to try it out now
dlk30341 ( ) posted Tue, 02 December 2008 at 11:33 AM · edited Tue, 02 December 2008 at 11:34 AM
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=1784236&member
See this image - I'm trying to figure out how the artist got those snow blobs on the leaves/branches....is he eco'ing rocks/metablobs?  Referring to the trees in the foreground.
gillbrooks ( ) posted Tue, 02 December 2008 at 11:52 AM
They could possibly be the snowy trees from RDNA - looks very much like them but I may be wrong (doesn't happen very often hahaaaaaaaaa)
Gill
Thelby ( ) posted Tue, 02 December 2008 at 12:00 PM
Quote - See this image - I'm trying to figure out how the artist got those snow blobs on the leaves/branches....is he eco'ing rocks/metablobs?  Referring to the trees in the foreground.
If you look close enough it appears to be 1 tree slightly rotated a bit and resized per instance, so just as a guess, I would say he modeled this tree to look like that and I might add did a Fantastic job of it!!!
Also, look at the trees in the background, especially the tops. I think there is only 1 or 2 trees there as well!!! Just my 10 cents worth, thats 2 cents adjusted for inflation.
I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
dlk30341 ( ) posted Tue, 02 December 2008 at 12:02 PM
The trees in the background are the RDNA snowy pines - the snow part is relatively flat not lumpy like in the foreground.  I want lumpy snow on my trees :( :lol:
dlk30341 ( ) posted Tue, 02 December 2008 at 12:28 PM
This was just a test, playing around.  I gouged out a terrain - flipped it up & moved it into the tree.  Not very good, but a start.
Mari-Anne ( ) posted Wed, 17 December 2008 at 4:36 PM
I really admired the image to which you refer so I emailed the artist and asked if he might consider sharing how he made the snow.  Here's his response:
This Tree was a present from Jan Walter Schliep (Walli) well known as a modeller at cornucopia. We sometimes change our models or work as betatester for other modeller friends.
The snow roof, I created with SILO, a good subdivision Proggie. Its a modelling program.
keenart ( ) posted Thu, 18 December 2008 at 6:02 PM
Debbie,
I use a round about method. I create a few snow blobs as objects and then eco-populate a pine. Then I turn it into an alpha.
jankeen.com
