Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
If you don't care about reflections and just want a reflective look, you can always use reflection maps instead of a full reflective material.
Depending on your scene, that could do the trick for large surfaces.
The problem isn't the reflective material, but the perfectness of the surface. Think of those reflective office buildings one oftens sees in skyline pics. Because the glass surface of the building isn't perfect, the reflection becomes distorted somewhat. It is very difficult to create a perfectly shaped large object.
Adding a slight displacement to the model, or as Rutra suggests, a small bump map might help.
When I was a kid building Airfix models and the like, one of the rules I remember of painting was that the shiny surfaces of large objects (ships, aeroplanes) should not be painted gloss.
So I'm wondering how this applies if at all to rendering, and whether I can rely on the rendering engine to deal with the scale issue. Blurring reflections is a possible approach, but render times on reflective spacecraft is already killing my computer as it is!!
Any thoughts on this?
www.CambrianMoons.com
