I want to know about Poser 8 too!
There are some unplublished 'hooks' in Poser 7 to get radiosity going, but very primitive and not optimized for speed in any way; it is very slow. That is not a 'criticisim' because PoserGI is not officially supported. I only bring it up to note that the "hooks are there."
I sent a note to Stefen about it but have not heard back yet.
:::::: Opera :::::
tony, the effect you describe (causing a posersurface to emit lite and to illuminate
surrounding posersurfaces) is possible in poser 7 and later. see page 109 of
poser python manual (p. 113 of pdf file) for further info. this effect is superior to
the fake method that's currently supported (gather node) in that it gives far denser
photon mapping.
we are awaiting word on whether poser 8 will have a rendering engine more
compatible with this effect, as FFRender's calculational abilities are taken to the
limit of all known desktop computers when the variables on page 109 et seq. are
enabled IMVHO. as always, beta testers are strongly advised not to say anything.
the problem with gather node however is that you can't use other lights except the glowing effect surface...
But please, if MM is a Poser variable, being a list of materials, how do I write a Poser script fragment to set each component material of MM to emit light that can illuminate other things?
gather nodes and ambient material settings. there's threads here about it.
But this forum has thousands of threads to look through.
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3339848&ebot_calc_page#message_3339848
tony, see att lnk. to cause a posersurface to emit lite, use non-zero alternate diffuse value, run stefan's script, then use FFRender/ray-tracing.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
When is Poser 8 likely to come? What new features will it have?
Is it likely to have true radiosity?
When will Poser have an ability for any surface (not only point sources and parallel sources) to emit light which can illuminate other things (either as set by a color and a value, or as a "luminance map")? What is this ability called? (I can make things shine now, by the "ambience" setting, but that light cannot illuminate other things.)
Will Poser have an ability to make a volume foggy?
