I dont get those maps, but if it is image based it can be used in Carrara and Poser too.
Follow me at euQfiz Digital
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=425755
The map are apparently 16bit TIFFs which can be used by D|S, P7, and PPro (see attached link).DAZ was probably playing safe by applying the D|S only tag.
What's more annoying is that recent D|S only products have had product codes starting with "ps_" rather than "ds_".
I am using those maps in Poser 7 just fine.
There are also two phython scripts posted on the Daz Forum, and on RDNA, which will apply the partial nodes exactly where they need to go.
Personally I set up shader spider partial FX shaders, but those scripts are very very good.
So don't be put off by the "DS only" thing, if you have P7. (This won't work in P6 and below)
If you are on P7, then the "DS only" just applies to the MAT files, really.
Silke
I've tried it on the M4V4 and it didn't seem to fit. :)
But on M4... nice. Very nice.
I've just posted an image to the gallery here if you want to see. :)
Warning! Nudity!
http://www.renderosity.com/mod/gallery/index.php?image_id=1801343
Silke
You may showing those maps only for a few of renderings, but you can't use it always. Don't know if does have a sense, just trying to explain.
In this rendering am showing a fast work done with the displacement map worked on the skin texture of THIS character. Wouldn't go with any other. (Beeing an intim character's part I had to hide half of it).
What DAZ did is technically right because is an accurate work, but does not consder the difference between each human people. Mostly if we speak of veins.
Andy
Hi, does anyone know of any displacement map free or for sale that can give Victoria 4 a veiny look similar to this one for Michael 4? Thanks for any help.
