Tue, Feb 11, 5:14 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 10 2:42 pm)
Carrara Free Stuff here.
Subject: Vertex Cube Smoothing?
chuckerii ( ) posted Sun, 21 December 2008 at 9:38 PM · edited Tue, 11 February 2025 at 4:54 AM
Trying to make friends with the vertex modeler after many years of spline modeling.  I'm a little confused by this one... I insert a 3d cube in the vertex modeler and applying smoothing to it.  Nothing happens.  the corners and edges remain sharp.  I compare this to Hexagon where if you smooth a cube, it rounds all the corners and edges.   Is it not possible to smooth a cube in Carrara's vertex modeler, or what am I missing?
Chuck
Miss Nancy ( ) posted Sun, 21 December 2008 at 11:12 PM
it smooths it , if ya subdivide and weld first.
JohnMalv ( ) posted Mon, 22 December 2008 at 12:05 AM
Quote - Trying to make friends with the vertex modeler after many years of spline modeling.  I'm a little confused by this one... I insert a 3d cube in the vertex modeler and applying smoothing to it.  Nothing happens.  the corners and edges remain sharp.  I compare this to Hexagon where if you smooth a cube, it rounds all the corners and edges.   Is it not possible to smooth a cube in Carrara's vertex modeler, or what am I missing?
Chuck
Hey Chuck -
Cubes are created with creased edges. Select the cube so all faces turn red, then select "smooth edges" from the model menu. Then it will behave like Hex. Creased edges are blue when unselected and yellow when selected. Smooth edges are gray when unselected and red when selected. It confused me at first too.
John
GKDantas ( ) posted Mon, 22 December 2008 at 5:49 AM
Yes John is right, theres to kind of smooth: for polys and for edges, so in some cases (almost all) you will need to smooth the edges too in the model menu. This option let you use creased edges in smoothed objects.
Follow me at euQfiz Digital
chuckerii ( ) posted Mon, 22 December 2008 at 8:43 AM
Quote - Hey Chuck -
John
Thanks so much John!  Very clear and easy explanation... I appreciate the help.
Chuck
