Sun, Feb 2, 7:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Question about export options
smalll ( ) posted Fri, 26 December 2008 at 6:05 AM · edited Sun, 02 February 2025 at 7:41 PM
Hi.
I need your help.
I uesd Poser pro(8).
And I want to export poser 4 people to obj file.
But I can't check "Export object groups for each body part"
How can I check it?
Can you help me?
patorak ( ) posted Fri, 26 December 2008 at 7:29 AM
Hey Smalll
How's it going?  Great,  I hope.
First things first,  have you read through Doc Geep's tutorials?  How about PhilC's tutorials,  have you read through them?  If not I suggest you do so.  From my point of view,  they are the best way to learn and understand Poser.
hborre ( ) posted Fri, 26 December 2008 at 7:57 AM
Online Now!
@ patorak:  those will be great starting points for any newbie except in small's case, English is not her first language.
@ small: if you are going to export a an entire figure to obj, make sure the entire figure is checked off in the hierarchy editor with universe unchecked.  Export the figure and uncheck 'As Morph Target (no world transformation).
Question: what exactly would you like to doe with these obj files?
smalll ( ) posted Fri, 26 December 2008 at 8:45 AM
**Nice to see you.
Thank you patorak.
I tried learn geep's tutorial.
I am tring now.
Hi, hborre.
Thank you your help.
You are exactly right.
My english is poor.
I'm sorry.
And I want to make morph.
I'm studing poser now.
Thank you about your answer.**
patorak ( ) posted Fri, 26 December 2008 at 8:51 AM
Hi Smalll
You're welcome.  I wonder if we could get Doc's tutorials translated?
smalll ( ) posted Fri, 26 December 2008 at 9:11 AM
Exucuse me, patorak.
Can I know where do you leave?
I mean... your country.
Because, you want to know translated Doc's tutorial.
It is surprise a little bit to me.
patorak ( ) posted Fri, 26 December 2008 at 9:33 AM
Middle-Earth.  Our queen,  Galadriel,  wants Doc's tutorials translated into tengwar.
http://www.babylon.com/definition/tengwar/Japanese
smalll ( ) posted Fri, 26 December 2008 at 5:43 PM
I'm sorry.
I could not solve the problem.
Next is export option.
How can I check it?
And **patorak, I download the program.
It is very good.
Thank you.
(You live good country.)
hborre ( ) posted Fri, 26 December 2008 at 6:45 PM
Online Now!
In your export options, check the box next to 'Body'.  I noticed it is unchecked.
smalll ( ) posted Fri, 26 December 2008 at 8:03 PM
Hi, hborre.
Thanks to you about interest my problem.
I did by your advice.
Please see below image.
I can't check it
Please help me. It is important to me
hborre ( ) posted Fri, 26 December 2008 at 9:19 PM
Online Now!
I also have PoserPro and I just check the settings for exporting a figure as an object.  As I understand it, you want to export the entire figure.  In the select object, make sure that all the body parts are selected.  Uncheck Universe and Ground.  Leave the Export Options the way it appears.  Click OK, then open your obj file in the Morphing application of your choice.  If you intend to load your new morphs as Morph Targets, then please check 'As Morph Target' when exporting.
When you open your obj file in the new application program, the entire figure will load in.  Hope this helps.  Let me know if this is what you want.
Online Now!
smalll ( ) posted Fri, 26 December 2008 at 9:33 PM
**Thanks to hborre.
**To be frank with you, I do not want always entire figure to obj file.
I removed Poser pro and reinstall.
But the result is same.
So I will format my notebook.
hborre ( ) posted Fri, 26 December 2008 at 9:41 PM
Online Now!
There is no need to reinstall the Poser.  I think you are misinterpreting that selection in the Export Options window.  The option you are pointing to is also grayed out on my program.  That option is not necessary for what you want to do.  Again, if you want to use the morphed obj as a morph target then you need to have 'As Morph Target' checked.  Now if you really intend to morph your obj for importing back into Poser, then leave that option unchecked.
smalll ( ) posted Fri, 26 December 2008 at 9:49 PM
I see...
I'll try.
Thanks to you.
You spent a lot of time to solve my problem.
Thank you.
patorak ( ) posted Fri, 26 December 2008 at 10:25 PM
And patorak, I download the program.
It is very good.
Thank you.
Hi Smalll
You are most welcome,  friend.
smalll ( ) posted Fri, 02 January 2009 at 8:42 PM
Dear patorak, thanks to you.
