Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
@ patorak: those will be great starting points for any newbie except in small's case, English is not her first language.
@ small: if you are going to export a an entire figure to obj, make sure the entire figure is checked off in the hierarchy editor with universe unchecked. Export the figure and uncheck 'As Morph Target (no world transformation).
Question: what exactly would you like to doe with these obj files?
Middle-Earth. Our queen, Galadriel, wants Doc's tutorials translated into tengwar.
I also have PoserPro and I just check the settings for exporting a figure as an object. As I understand it, you want to export the entire figure. In the select object, make sure that all the body parts are selected. Uncheck Universe and Ground. Leave the Export Options the way it appears. Click OK, then open your obj file in the Morphing application of your choice. If you intend to load your new morphs as Morph Targets, then please check 'As Morph Target' when exporting.
When you open your obj file in the new application program, the entire figure will load in. Hope this helps. Let me know if this is what you want.
There is no need to reinstall the Poser. I think you are misinterpreting that selection in the Export Options window. The option you are pointing to is also grayed out on my program. That option is not necessary for what you want to do. Again, if you want to use the morphed obj as a morph target then you need to have 'As Morph Target' checked. Now if you really intend to morph your obj for importing back into Poser, then leave that option unchecked.
Hi.
I need your help.
I uesd Poser pro(8).
And I want to export poser 4 people to obj file.
But I can't check "Export object groups for each body part"
How can I check it?
Can you help me?
