ok. It looks like the problem occurs when you lower the arm. So I would try to move the center point of the SHIRT collar away from the neck of the woman. Go to window->joint editor and a window will pop up already in center mode. So just move the green crosshairs around then lower the arm to test it out. I don't have that coat so you will have to experiment with the centerpoint to see what works best. But make sure you don't move the woman's collar joints by accident. They are named the same. So check to see that you are working on the correct figure. Conformed clothes become figures. That's how they are able to move with the body they are attached to. Good Luck Scott Ayers iamsba@aol.com
