In poser... Turn off "Use External Binary Morphs" under your options/settings.
anything you created using V4 prior to this will not load correctly, but after applying this setting, everything should be fine =D
Rarer than a hairy egg and madder than a box of frogs....
< o > < o > You've been
VUED! < o > < o >
O
O
I have some problems when I try to import a Vicky 4 into my Vue 6 - all the poses are gone and V4 is "zero-posed". Is this a bug? There's no problem when I use a Vicky 3... This only happens to V4.
What can I do to import my scene into Vue without exporting it as a obj-file from within poser 7?
