Fri, Jan 24, 11:47 AM CST
Subject: Vue and Poser Victoria 4
ARCHITECT ( ) posted Sat, 10 January 2009 at 3:44 AM · edited Fri, 24 January 2025 at 4:19 AM
I have some problems when I try to import a Vicky 4 into my Vue 6 - all the poses are gone and V4 is "zero-posed". Is this a bug? There's no problem when I use a Vicky 3... This only happens to V4.
What can I do to import my scene into Vue without exporting it as a obj-file from within poser 7?
melikia ( ) posted Sat, 10 January 2009 at 3:49 AM
In poser... Turn off "Use External Binary Morphs" under your options/settings.
anything you created using V4 prior to this will not load correctly, but after applying this setting, everything should be fine =D
Rarer than a hairy egg and madder than a box of frogs....
< o > < o >    You've been VUED!    < o > < o >
         O                                                    O
thefixer ( ) posted Sat, 10 January 2009 at 3:56 AM
Also if you've used dynamic cloth, you need to bring her in at the final frame of the series.
E.g. If you used dynamic cloth up to frame 30, bring her into Vue at frame 30 or 29, I always use 29!
Injustice will be avenged.
Cofiwch Dryweryn.
