Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Attached Link: http://Cyber-Fyber.bbay.com/images/CF-DLfiles/SketchDesignTutorial.pdf.zip
You can download my free Sketch Design Tutorial at this URL. It shows how to get very high DPIs. and how to combine different Dispaly Settings (smooth shaded and wireframe, etc.) in one render. You can also see 88 different and new sketch design presets at Bbay, including traditional media and comix styles... and a pencil style superior to the standard P4 preset. de nada -3DonPam- Under the Render menu, choose Render Options. You will see a place to render to a new window. In those settings you can specify the size of the new window where the render will happen and at what resolution you want. Choose your Sketch Design style. Choose Sketch Render under the Render menu. A new window will open and the Sketch Render will appear. If the window and resolution settings are high you will see a corner of the rendering taking place. Once complete you can scroll to see it all. Save the image. open in an image editor like Photoshop and save it in that program. The file size will reduce and you will be able to do post rendering work. -3Don
Is it possible to make a sketch rendering (the one that looks like pencil drawing) outside the main Poser window? - so that I can render larger images with more dpis :-) gracias
