Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
Does this have any kind of transmap applied? Or is it just a texture overlay?
In both cases you can fairly easily make a displacement map.
It's easiest if there's a transmap, in that case you can justplug that into the displacement node (and turn it down from the outrageous 2.54 it defaults at)
If there's no transmap ad this is a texture overlay it's almost as easy, providing you have either Photoshop or PSP.
Take the overlay and make a monochrome (black/white/desaturated) copy of it. Boost the brightness so it's almost white and put it on a new, black layer. Save and use as displacement map.You might want to give it a slight blur to even out the edges,
Hope it makes sense :)
What do you suggest now?
Larger one has the displacement map.
![file_422566.jpg](https://live.cdn.renderosity.com/forum/threads/2761829/file_422566.jpg)
First of all I want to thank everyone who helped me find the stockings I wanted. Now I need how to make a displacement map for them. I have made a texture and everything is looking good, but when I render it using V4 texture... it's looking 'flat' I played around with 'transparent' nodes and tried 'bump' maps, but I think it's a displacement I need.
