Sun, Jan 26, 5:54 PM CST
Subject: Displacement map for stockings
chaylastorm ( ) posted Sun, 25 January 2009 at 8:05 PM · edited Sun, 26 January 2025 at 5:48 PM
 First of all I want to thank everyone who helped me find the stockings I wanted. Now I need how to make a displacement map for them. I have made a texture and everything is looking good, but when I render it using V4 texture... it's looking 'flat' I played around with 'transparent' nodes and tried 'bump' maps, but I think it's a displacement I need.
TrekkieGrrrl ( ) posted Sun, 25 January 2009 at 8:16 PM · edited Sun, 25 January 2009 at 8:16 PM
Does this have any kind of transmap applied? Or is it just a texture overlay?
In both cases you can fairly easily make a displacement map.
It's easiest if there's a transmap, in that case you can justplug that into the displacement node (and turn it down from the outrageous 2.54 it defaults at)
If there's no transmap ad this is a texture overlay it's almost as easy, providing you have either Photoshop or PSP.
Take the overlay and make a monochrome (black/white/desaturated) copy of it. Boost the brightness so it's almost white and put it on a new, black layer. Save and use as displacement map.You might want to give it a slight blur to even out the edges,
Hope it makes sense :)
chaylastorm ( ) posted Sun, 25 January 2009 at 8:25 PM
 thanks Trekkiegirl for answering so quickly. I have no idea what a transmap is...lol  ... this is just a texture.  I'll give it a go as soon as I find out what I did to get the stockings on her in the first place.  hehehe
chaylastorm ( ) posted Sun, 25 January 2009 at 9:25 PM
 OK. got that sorted out. Now I made the displacement map (which is really a 'transparent map' isn't it?) added it and then 'upped' the value to 1 as I couldn't see any difference. This is what I got.. which still doesn't look any different. I have a tut. on making displacement maps and second skins by SVDL, but it's been done on a PC and there are subtle differences and it's just not working with my mac.
What do you suggest now?
Larger one has the displacement map.
Nevare ( ) posted Sun, 25 January 2009 at 9:43 PM
Do you have displacement enabled in the render settings?
chaylastorm ( ) posted Sun, 25 January 2009 at 9:50 PM
 Oppps.....smiles  Will try again..
chaylastorm ( ) posted Sun, 25 January 2009 at 9:56 PM
 Ohhh... wow... that worked.  Thank you so very much.. now I shall just play around with the values till I get what I like.
Anthanasius ( ) posted Mon, 26 January 2009 at 10:16 AM
Hi !
Have a look here i've adding a stocking top for the shader of BB ;-)
www.renderosity.com/mod/forumpro/showthread.php
Génération mobiles Le Forum / Le Site
