Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Quote - Remember that with the bend modifier you can change the value beyond slider so maybe you can reach a full ring using a value of 360.
-TOXE
Hey Davide... thanks for the tip about changing the value beyond the slider - that did give me a full ring. However, I'm interested in trying the animated alpha channel. Can you explain how you would approach that techinque to make a torus grow? Thanks.
Chuck
Anybody have an idea of how I can smoothly animate a torus shape starting from a circle to a full ring? Kind of like the circle drawing a ring as it extrudes? Right now I am animating the circle shape in the spline modeler, extruding it over a 1 second time frame while at the same time applying a bend modifier to the object over the same 1 second time frame. It's close, but I can see it bending a bit as it goes along instead of a smooth arc. Also, with the bend modify I can only do a half ring. Any better ideas to achieve this? Thanks!
Chucker
