Tue, Nov 12, 8:05 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Animated Torus shape?
chuckerii ( ) posted Sun, 15 February 2009 at 9:36 PM · edited Sun, 10 November 2024 at 2:36 AM
Anybody have an idea of how I can smoothly animate a torus shape starting from a circle to a full ring?  Kind of like the circle drawing a ring as it extrudes?  Right now I am animating the circle shape in the spline modeler, extruding it over a 1 second time frame while at the same time applying a bend modifier to the object over the same 1 second time frame.  It's close, but I can see it bending a bit as it goes along instead of a smooth arc.  Also, with the bend modify I can only do a half ring.  Any better ideas to achieve this?  Thanks!
Chucker
TOXE ( ) posted Mon, 16 February 2009 at 2:23 AM
Hi Chuck,
maybe the fastest way is to create an animated alpha mask, but i'll let you know if i found something better.
-TOXE
TOXE ( ) posted Mon, 16 February 2009 at 2:26 AM
Remember that with the bend modifier you can change the value beyond slider so maybe you can reach a full ring using a value of 360.
-TOXE
chuckerii ( ) posted Mon, 16 February 2009 at 8:40 AM
Quote - Remember that with the bend modifier you can change the value beyond slider so maybe you can reach a full ring using a value of 360.
-TOXE
Hey Davide... thanks for the tip about changing the value beyond the slider - that did give me a full ring.  However, I'm interested in trying the animated alpha channel.  Can you explain how you would approach that techinque to make a torus grow?  Thanks.
Chuck
TOXE ( ) posted Mon, 16 February 2009 at 9:17 AM
file_424326.mov
Hi Chuck,
this is a simple test, you need to UV the torus and usa a simple movie in the alpha channel.
I've Uvmapped the torus with modo because it's too simple, but you can use also Carrara.
Davide
-TOXE
TOXE ( ) posted Mon, 16 February 2009 at 9:17 AM · edited Mon, 16 February 2009 at 9:19 AM
file_424329.txt
...and the files, change the name to .zip
D
chuckerii ( ) posted Mon, 16 February 2009 at 9:38 AM
Ahhh... very easy.  Thanks so much Davide!
Chuck
TOXE ( ) posted Mon, 16 February 2009 at 9:42 AM
You know, every time that someone here ask for something for me is a challenge;-)
-TOXE
chuckerii ( ) posted Mon, 16 February 2009 at 10:07 AM
I appreciate you taking the time to figure it out and posting the files.  Thanks again.
Chuck
