Mon, Dec 2, 5:47 AM CST
Subject: Can`t work out Morph++
Sambucus ( ) posted Mon, 16 February 2009 at 11:31 AM · edited Mon, 02 December 2024 at 5:44 AM
I`m trying to load the Uncle Albert figure into P7. I load Daz people/M4 then Poses/daz m4/morph injections/inj morphs++M4. I then go to Poses M4 Uncle Albert/full inj then in the parameters Community/Uncle Albert full. Moving the dial changes the figure, but not to Uncle Albert unless he`s supposed to have his tongue coming out the bottom of his jaw. What am I doing wrong. Or can someone please point me to a tute on using Morph++ and Inj/Rem files because I just can`t seem to work them out. Thanks
Anniebel ( ) posted Mon, 16 February 2009 at 1:08 PM
Usually you don't have to INJ Morphs ++ first, I don't have this product, but the Uncle Albert INJ should call the morphs++, load & set him up, you shouldn't need to set a dial, usually it is automatic.
Do any other characters INJ properly? Maybe you need to reinstall Morphs++. Did you run the initialization script after installing Morphs++?
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
hborre ( ) posted Mon, 16 February 2009 at 1:08 PM
There should be a dial labeled Uncle Albert in the parameter panel where you can apply the morph.
Anniebel ( ) posted Mon, 16 February 2009 at 1:17 PM
Quote - There should be a dial labeled Uncle Albert in the parameter panel where you can apply the morph.
He already said quite clearly that using the dial didn't help!
I really suspect it is because Morphs++ hasn't been initialized
Helen Keller
IsaoShi ( ) posted Mon, 16 February 2009 at 1:58 PM · edited Mon, 16 February 2009 at 2:00 PM
Step by step....
Before you inject the Morphs++, you should see an empty Morphs++ container under Morphforms in your figure's body parameters. If it's not there, Anniebel is right and you did not initialise your M4 figure after installing the Morphs++ product.
After you have injected Morphs++, the container should now be populated with the Morphs++ parameter dials, as in my screen shot (yes, that's V4.2, but it works the same way). If it's still empty, there is something going wrong with the Morphs++ injection, which I personally would try to sort out first, before injecting the character.
If the Morphs++ dials show up correctly, and work when you twiddle them, I would suspect the character package itself, and contact the vendor for help.
Sambucus ( ) posted Mon, 16 February 2009 at 3:05 PM · edited Mon, 16 February 2009 at 3:06 PM
Thanks for all the replies. This is what I get if I dial in 1.000 under Uncle Albert. I think the Morph++ set up must be OK because I get just what is shown in the previous post, and I can get Vlad to work (once I`d found  where everything was. It this a complicated system or what? ) I`ll try reinstalling UA.
Marieah ( ) posted Mon, 16 February 2009 at 7:57 PM
I'm pleased you got him to work okay.
Sambucus ( ) posted Mon, 16 February 2009 at 8:08 PM
Marieah, did I get him to work?, The pointed earlobes, those bags under the eyes, the whole eye area come to that. Is that how he`s supposed to look?
bnetta ( ) posted Mon, 16 February 2009 at 8:37 PM · edited Mon, 16 February 2009 at 8:39 PM
sambucus
try this zero/restore your m4 , all your morph dials.
then only move the uncle morph dial,
you should get the intended character if you set it to 1. again and get the same thing,
dial it back down. as the above pic looks over done
also check that the eye bags, ect.... morphs in ++ are not over dialed
as the  daz promo pic  doesn't look like yours.......lol
he seems to be melting..lol
www.oodlesdoodles.com
Marieah ( ) posted Mon, 16 February 2009 at 9:53 PM
No, that image doesn't look right, but it looks better.
Try injecting just into the base m4 as it's a custom morph and should not need the morphs plus...
Sambucus ( ) posted Tue, 17 February 2009 at 8:43 AM
Think I`ve sorted it out now, at least I got him looking right once and saved it. Thanks again for all the suggestions.
Marieah ( ) posted Tue, 17 February 2009 at 8:46 AM
I'm very pleased about that, and hope to see your render sometime soon!
